Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 05-05-2011, 11:48 PM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
Default Son of a.... Friggin c0200 code... What?
Okaaaaay. so I looked this code up and found a Russian page that actually had the dodge code, and it says it's a wheel speed sensor... Right front to be exact... Looking under the vehicle... no wheel sensor? I know where it SHOULD be, but it's not there. Anyone have another explanation for that c0200 code? Note: It is not P0200.
'04
Dodge
Ram 1500
2 wheel drive
Old 05-06-2011, 04:57 PM
Yup...that's the read I get too...speed sensor. Maybe the code is being set because the sensor is gone?
Old 05-07-2011, 02:27 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
how did you get that code? i would go to autozone and have them scan it- their scanner tells exactly what it is.
if performance is something you're looking for, nows the time to talk the wife into investing in a superchips flashpaq "code reader" ...
Old 05-09-2011, 11:29 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Where did you get that code? Not saying you are wrong but I can't seem to find that code linked to a Dodge Ram.
Is your ABS light on? If it is a faulty front wheel speed sensor then it is only used for you ABS system and the ABS light should be on.
I don't know how accurate it is but I read on eHow that 2WD Rams only have rear ABS. That doesn't make a lot of sense to me because I would think it would be more beneficial on the front. But it would explain why you can't find the sensor and your ABS light isn't on (if it isn't that is).
Old 05-17-2011, 10:55 PM
Rep:22
Turns out that while the vehicle doesn't have front wheel sensors, the connectors are there... weird... At any rate, the code cleared itself and I went on my merry.
AutoZone's code reader didn't pull the code. It was only through my OBDII reader on my phone that I got any kind of code. It was a Chassis code. They occasionally make the mistake of thinking chassis codes are powertrain codes. I had to correct them on one of them before.
need help with p1128 dtc code nitro1965 5.7L V8 Specific Topics 8 10-21-2015 04:19 PM
Threw code on 06 4.7 15 miles from dealership starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-28-2011 10:27 AM
P0753 Code stmabe 5.9L V8 Specific Topics 4 11-18-2010 09:38 AM
Just got a code P0205...please help LSxFBODYgen3 4.7L PowerTech V8 Specific Topics 4 04-30-2010 03:58 PM
03 dodge ram 3500 code p0123 quality03ram Newbie Checkin! 7 01-22-2010 03:51 PM
