United Radio
Old 05-06-2011, 12:13 AM
coolassdodge coolassdodge is offline
Vehicle: 2006 Dodge Ram 1500
coolassdodge is on a distinguished road
Default WTF PCV valve mystery
so i went and proactivly ordered and purchased a brand new pcv valve. Now the store had the part it matched my vin number model year and truck went to install it in accordance with the boys at Haynes. hell of it is i cannot find it for the life of me. And it is most definatly not on my oil filler neck or valve covers i already checked a lot of times. Please help !!!!!!!!!! its 2006 4.7L SLT single cab with 2 metric shit tons of bed space go ahead call it a "work truck" i dare you.
Old 05-06-2011, 10:43 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Is this similar to what your Haynes manual shows? This is obviously from a Jeep but I think it's supposed to be in the same location.
Old 05-06-2011, 03:41 PM
That ^^^^ is the correct location and orientation of the PCV valve on the 4.7L Ram.
Old 05-07-2011, 02:47 AM
Kelr31 Kelr31 is offline
Vehicle: 2007 Dodge Ram
Color: Orange
Kelr31 is on a distinguished road
That's not where the pcv valve is on my 07 4.7L Ram or what it looks like. The picture posted is the part I got when I went to a local shop to get one, but for my truck that wasn't the right part. I had to go to a Dodge dealer to get the right valve. On my truck the pcv valve is located on the driver side around the back of the intake manifold. It's threaded on one end and the hose goes over the other.
Old 05-09-2011, 10:09 AM
Rep:367
Well I'll be damned. Everything I have ever read says the valve was where that illustration shows. I had never looked for mine in the short amount of time I have had my truck because I had the dealer change it at the last service. But I looked yesterday and it sure isn't there. I'll have to look next chance I get but I'm sure you are right Kelr31.
Old 05-14-2011, 11:41 PM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
Just did mine yesterday, got it for under five bucks and installed it in 10 seconds...it was pretty oily looking, put it where the photo on page one says.
Old 05-16-2011, 10:10 AM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
I had a 2001 Ford F150 a few years ago. It was a 1/2 year model, so some time through the year of production they changed a few things. One being the fuel filter type and location.
Maybe this is the case with the Dodge Ram and the PCV?
Old 01-23-2012, 12:56 PM
MaleNurse MaleNurse is offline
Vehicle: 2006 Dodge Ram 1500 SLT 4x4
Trim Level: SLT Big Horn Edition
Color: Charcoal
MaleNurse is on a distinguished road
I am having this same issue and I assure you, sir, it is NOT on the oil filler tube. Kelr31, I wish you could provide a picture I have searched for one for hours online. I really hate to pay a shop to change something so simple. I do realize that this thread is 8 months old and that no one will probably respond. oh well.
Old 01-23-2012, 02:17 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
There have been a few different locations on the 4.7L's over the years. From what I know...on pre 2008 4.7L's the pcv valve is USUALLY on the oil filler neck. I believe some years had them on the valve covers. On 2008 and newer 4.7L's the pcv valve is on the rear of the driver's side valve cover on all engines (as far as I know).
Sean
Old 03-11-2012, 02:11 PM
gasser5 gasser5 is offline
Vehicle: 2007 Dodge Ram 1500 4.7L
Trim Level: SLT 4X4
gasser5 is on a distinguished road
I'm a little late to the party but I have been trying to figure this one out for quite a while. My 2007 Ram is a 4.7L FLEXFUEL. Finally found out that yes, for this model the PCV valve is on the drivers side valve cover at the very back near the firewall. It does not look anything like the traditional PCV valves. It is about 4 inches long and BOLTS into the valve cover. The hose still slips off the top of the valve easily though. It is not easy to get to but if you remove the air filter down to the throttle body, you can reach it with with some difficulty. I used a 34 mm deep socket. I had to use a 3/8" drive wrench with an adapter for 1/2" drive due to the limited space. The Dodge dealer part number is: 53032925AC and cost $20.25 at my local dealer. Hope this helps. On most other models, the PCV is located on the oil filler tube.
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 08:45 AM
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 11:17 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 04:59 PM
valve covers? bfinley Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 8 12-18-2010 01:47 PM
