your opinion please - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 05-06-2011, 02:11 AM
STORMIN503's Avatar
STORMIN503 STORMIN503 is offline
Vehicle: 1995 RAM 2500LD
Trim Level: 2500
Color: Blue-gray
STORMIN503 is on a distinguished road
Question your opinion please
So I just got a 1995 ram 2500hd. 5.9l I have been looking for a project and found it.. this ram was bought by a nursery at 53 miles in 95 and now has 100,970.. I got it from the only owner but it was a nursery truck. it's ugly beet and dirty.. It has a dana 70 rear end witch I thought only came in the diesel and v10 rams. I was told it was ordered from dodge that way for the nursery..?? any1 ever heard of that.? It had no shocks in the rear..!! why. I dont no.. I also got it with the bed resting on the frame with no bolts holding it on and the 5.9 in the bed. I'm betting it had a flatbed on it for the nursery. the seller said he had the bed off to put a better one on and changed his mined and sold it.. ya right... and he said the engine was out to be put in a ext. cab that had a 318.. and wen he quit the job and moved 4 hours away he had a change of plans,witch he did move, but I'm skeptical cause of the pieces I got it in..
I was told that it needs a new intake gasket but I'm betting it needs more than that.. for the low miles it is caked in grease..!!.. any1 know what size bolts hold the bed on.? or were I can get the bolts to bolt the engine to the tranny..?? lol.. to be honnest I would have passed on this but I got it for trade.. a miller 180 welder, stihl ts360 demo saw and a little hvlp turbine finisher, painter. to be exact.. he was askin $700 for the truck or $1000 with the engine.. I think I got a deal, He thinks he got a deal. .. so what do u think and were would u start.. I wanna lift it and beet the snot out of it but I have to make it a nice ride first... all options to..
Old 05-06-2011, 08:38 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about using the link in my SIG to jump on the Newbie Checkin to introduce yourself and posting a few photos of your truck? That way we can tell you how to proceed with that great deal!
Old 05-06-2011, 02:51 PM
whoa....sounds like you could start any place you wanted and make good progress...there's a lot of work there.
I'd check the engine for compression, pull the valve covers off, pull the pan, check the lower end.
Then I'd see what it's gonna take for getting the bed back on. Before you do that it will be a lot easier to put on some shocks without the bed on.
One thing you could do is break this truck down into it's component pieces and then tear those down, rebuild and re-assemble.
What a project!
Old 05-06-2011, 06:29 PM
Longshot's Avatar
Longshot Longshot is offline
Vehicle: 2007 ram 4x4 5.7 hemi
Trim Level: laramie
Color: red
Rep:104
Longshot will become famous soon enoughLongshot will become famous soon enough
With that engine out I would go ahead and overhaul it before I installed it. Check the parts list on a body lift for that truck it will list the bed bolt size I'm sure they are metric just subtract the amount of lift from the length.
07 Laramie 4x4 HEMI, ATX series Artillery wheels,Nitto295/60/20 terra grapplers,Predator,nerf bars,leveling kit,stainless door, tailgate handles, mirrors,Weather Tech floor liners,Airaid CAI,Flowmaster 40 series exhaust,Extang Trifecta Signature Series Tonneau,electric tailgate lock, vent visors
Old 05-09-2011, 03:57 AM
STORMIN503's Avatar
Trim Level: 2500
Color: Blue-gray
Default Update
thanks guys for your info.. So I got the engine ripped down to a short-block. the heads and valves are fine but I haven't pressure checked em yet.. the #8 cylinder had a nice rim at the top but all the others were fine..??? stuck ring maybe..?? I can still see the factory cross hatching in the cylinders.. .. but holy-molly the pistons sit down in there a ways at t.d.c... dose anybody no what compression ratio a 1995 5.9 gas. is.?? I heard It was something like 8.9 but read somewhere It was higher like 9.1 because of the year and they lowered it later.. since I want to put new slugs in it anyways I was thinking of putting forged pistons in it and raise compression to 10.5.. will the stock cam work with it that high.. what all am I looking at to raise the comp. a little.. I will pull the bottom end apart tomorrow and see were I lie on that end.. If it needs a crank I'm getting a forged 1 and make it a 408 with a 9.5 or 11.5 comp. ratio. but if not I would like to keep it stock and just replace the pistons to raise comp. a little.. will the bottom hold up to that..?? any suggestions are much appreciated..
Old 05-12-2011, 07:54 PM
ScatPak07's Avatar
Rep:970
Thats an awesome project you got going. Definitely would do the motor bfore putting it back in' which you doi g. Since you have the bed off I would suggest getting a body lift foe the truck. At let the bed is off already so half the work is done.
Old 05-13-2011, 06:34 AM
STORMIN503's Avatar
Trim Level: 2500
Color: Blue-gray
And with a little research I found out the guy I got this from Lied his butoxx off. its a 2500LD not HD. it has a Chrysler 9 1/4 rear and 44 front with a factory tube-truss brace. not the 60's I was expecting but they do have 8 lug rims and the axle numbers cross to a 2500LD. It has 3 1/4 blocks in the rear and huge lief packs. it sits up there.!. the fronts level now but it has the engine out. when I put it back in it should drop a few inches so I may get some spacers to level it. and I'm going with a cheep body lift. any suggestions.? cheap is the key word.. lol.. I have some engine work to do. everything looks good inside other than a ream at the top of the rear right 2 cilinders (#8 and the next 1 up in line.). so I want to go .030 over and make it a 365.. I would like to put in flat top pistons and raise comp. to 9.7 - 10.5 .. any suggestions on what else I may need other than a cam. will my computer run it with more compression. 1995 is obd1 .. and any suggestions on pistons.? .. thanks again guys..
Christopher S.
Old 05-14-2011, 01:40 AM
STORMIN503's Avatar
Trim Level: 2500
Color: Blue-gray
SO.. My VIN. brought up this trim level... LT HD Reg. Cab 8-ft. Bed 4WD .. weird?? and it has a 5 leif pack on the rear with 3-1/4in blocks.. the front is all spring but once I put the engine in I think I'm gonna need 2-1/2in spacers to level it out. Its raked now with no engine in it.. is that common for the rear...??. I had a 1997 1500 4x4 that sat about 3 to 4in lower than this one.
Old 05-14-2011, 05:30 PM
STORMIN503's Avatar
Trim Level: 2500
Color: Blue-gray
Default build sheet
Heres the build sheet..
Thank you for contacting the Ram Customer Assistance Center regarding
your 1995 Ram 2500.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
*P1 Premium Cloth 40/20/40 Bench Seat
ADAP Light Group
ADJ Heavy Duty Service Group
AHC Trailer Tow Group
AJKP Convenience Group
AJPP Power Convenience Group
APCA Center Band Two Tone Paint
ASPP SLT Decor Group
AWK Travel Convenience Group
BANP 120 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKBS Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSPS Passenger Assist Handle
CSRP Passenger Assist Handles
CUNP Overhead Console
CUVP Behind Seat Modular Storage System
CUYP Storage Tray
DGB All 4-Speed Automatic Transmissions
DGRS 4-Spd. Automatic 46RH Transmission
DHAS Lock-Up Torque Converter
DHHS Shift-on-the-Fly, 241 Transfer Case
DJCS 195MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRGS Corporate 9.25 HD Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GFD Rear Sliding Window
GNKP Rear View Auto Dim Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
JPS Power 6-Way Driver Seat
JRDP Power Driver Seat
K17P STRIPE/BADGE/MOLDING
LAAP Ignition Time Delay Lamp
LAGP Warning Chime
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MPFP Journey Badge
MWDP Removable Tailgate w/Caliper Latches
MXB Front Air Dam
MXCP Front Bumper Sight Shields
NAAS Federal Emissions
NBKS EVAP Control System
NFVS 35 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PCHA Brilliant Blue Pearl Coat
QACA Silver Star Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RAY AM/FM Cassette Radio w/Equalizer
RCEP Infinity Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBB Full Size Spare Tire
TBMP Tire Carrier Winch
TWPS LT225/75R16D BSW All Season Tires
TZHP Michelin Brand Tires
WDCP 16X6.5 Chrome Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMJP Center Hub
XBSS Pickup Box
XEFP Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email and have a great wwekend.
Sincerely,
Ralph
Customer Service Representative
Rim Size opinion chithead Dodge Ram R/T 108 06-04-2014 11:19 PM
I need an opinion about painted wheels Dave07RamHemi Dodge Ram Wheels And Tires 5 04-23-2011 06:08 PM
The 2nd Opinion RootBeer Jokes/Humor 7 12-23-2010 09:46 PM
Honest opinion mholla00 Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 42 06-07-2010 07:45 AM
I need you opinion bones64 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 30 01-22-2010 11:59 AM
