Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-07-2011, 02:44 PM
Saugie53 Saugie53 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: Hemi Sport
Saugie53 is on a distinguished road
Default Help with lower ball joint
I have tried everything I can think of to get my lower ball joint to pop free from the steering knuckle. The upper ball joint and tie-rod came out with the pickle fork no problem but the lower does not want to budge. I have been pounding on it with a block of wood and a 3lb sledge, even with the pickle fork wedged in it and I have a jack under the bolt for the ball joint and the whole weight of the truck on it the thing still wont budge...need to get this out so I can have my truck back togeather for monday...any suggestions are greatly appreciated thanks
Old 05-07-2011, 11:47 PM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
i had the same problem.. heat the spindle with a torch and hit the spindle directly with the hammer. lose the block of wood
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 05-08-2011, 04:54 PM
thanks I actually ended up barrowing another pickle fork from my neighbor before I read this post and I pounded mine in and then pounded his in between mine and the knuckle and got it to pop free the old ball joint pressed out no problem...thanks for the reply tho!!
Question With Ball Joint Press Saugie53 Suspension 2 05-05-2011 04:07 PM
Death wobble = axle swap fundaddy75 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 9 11-08-2010 10:50 PM
Lower ball joint falling out 98 ram1500 blodge5.2 Suspension 1 10-06-2010 07:47 AM
do ball joint make a cracking sound??? goatmilk2878 Drive Line 1 06-19-2010 09:13 AM
Lower ball joint issues bruno9 Newbie Checkin! 10 02-13-2010 01:10 AM
