Old 05-07-2011, 10:06 PM
rolledxj rolledxj is offline
Vehicle: 2011 ram 1500
Trim Level: SLT Outdoorsman
Color: Deepwater Blue
rolledxj is on a distinguished road
Default Brake Controller Operation
I received my brake controller a few days ago and installed it the same day. The installation instructions were very clear and thorough, however, apparently you are on your own for operating instructions.
I have owned and used many brake controllers, but I would like to know any specifcs about adjustment.
Anyone got a clue?
Old 05-13-2011, 06:09 PM
bigbadwillie's Avatar
bigbadwillie bigbadwillie is offline
Vehicle: 2011 Ram Sport
Trim Level: Sport Quad Cab
Color: Deep Cherry
bigbadwillie is on a distinguished road
i did some digging through the cd for correct operation. it recommends that you set your controller at 6 and drive between 35-40 mph and manually slide the arm over. if the brakes lock up on the trailer lower setting gradually and repeat. Hope this helps
Old 05-14-2011, 10:20 AM
Blackthunder's Avatar
Blackthunder Blackthunder is offline
Vehicle: 2011 Dodge Ram 2500 HD
Blackthunder is on a distinguished road
I know all trailers are different, but I keep mine on 6.0 setting and get just the right amount of trailer braking.
As said previously, it's something you have to play with, preferably in a parking lot.
Not sure if your aware of this, but I have read on this forum that if you add the factory brake controller, you need to have the vehicles software updated to accept the controller, via re-flash. I may be wrong on this and hopefully someone can chime in and either shoot me down or verify.
Old 05-14-2011, 12:41 PM
gingrbredman's Avatar
gingrbredman gingrbredman is offline
Vehicle: 2011 Ram 1500 Crew Sport
Rep:89
gingrbredman will become famous soon enough
The trailer brakes will work with just adding the new controller. No need to flash. If you do flash, then the EVIC will display the trailer brake controller in the system. The controller will work without the flash.
Think of it like adding a Prodigy. Correctly installing the Prodigy controller will add trailer braking, but no display on the EVIC.
Gusz 2011 RAM SPORT CC -Lockpick CHR550 -Hardwired Radar Detector - Custom Trailer Cam - -Fold a-Cover G4 - Bed Rug - Billet Shifter - Debadged - 18" Magnaflow - Custom Clear HID Projectors - LED Tailgate Bar - Custom Billet Badges -
2010 Ram Factory Trailer Brake Controller Install Netman66 Dodge Ram Knowledge Base 334 04-17-2014 02:51 PM
Installing Factory Brake Controller brc3858 2010 Dodge Ram Forum 17 05-07-2013 09:02 PM
Adding a electric brake controller dave k Electrical 3 08-06-2010 11:36 AM
Installing Tekonsha Brake Controller - No Power mullinon 2010 Dodge Ram Forum 6 07-15-2010 02:04 PM
led third brake light/brake controller pa03hemi Custom Dodge Ram Interior and Exterior Lighting 3 05-20-2010 04:26 PM
