Old 05-08-2011, 02:31 AM
Stuck2theAxles's Avatar
Stuck2theAxles Stuck2theAxles is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT BigHorn
Color: Gray
Rep:108
Stuck2theAxles will become famous soon enoughStuck2theAxles will become famous soon enough
Default Gears Gears Gears Who's tried em all ????
bought a 2010 loved the way it looked and loved the truck so much didnt bother to see the options and low and behold i have 3 twenty something gears and it still seems to get out of its way pretty well with the pooper chips and KN but i drive alot of tundra's at work and maaaan do those 4:30s do work does any one have a truck with 3.55 3.92 or 4.10 and have drivin one with 3.21s is the difference pretty huuge or do i need a supercharger or longtubes and cam to get the huge gains out of this truck
2011 CCSB Sport 2WD - McGaughys, FOOSE , shaved clean and newly added DIABLO SPORT !!
2012 CCSB Lone Star 4WD - McGaughys , KMC, shaved clean
2012 CC 2500 Cummins - Thuren, Fox , H&S w deletes upstairs and down
Old 05-08-2011, 02:41 AM
Rep:2705
3.21 is the best for MPG & not much else
3.55 is a bit less for MPG & can tow light trailers
3.92 a less again on MPG, & is an acceptable towing vehicle
4.11 gets less mileage, better towing capacity & does decent on a drag strip
4.56 starts in the range of NO gas mileage, more in the range of gallons per mile, but you can pull a loaded semi truck
hope this gives you a simplified explanation
Old 05-08-2011, 10:01 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Color: Burgandy
Rep:160
^^^^That pretty much sums it up^^^^ In layman's terms, you couldn't be more clear.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE COMING SOON!
Old 05-08-2011, 10:04 AM
Color: Burgandy
Rep:160
The best bang for the buck are the 3:92's, small penalty in the gas economy department, limited slip rear-end, rated to pull respectable loads.
Ctmrxmas's Avatar
Ctmrxmas Ctmrxmas is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona #2668
Rep:24
Ctmrxmas is on a distinguished road
Gears will definitely wake up your truck! Should probably be the first thing you do!
Old 05-08-2011, 10:21 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
4.88's - holeshots to the speed limit.
4.10 gears and limited slip installed smartel 2009 Dodge Ram Forum 24 04-25-2011 11:37 PM
New Gears, what type of gear oil should I run?? elcliffo 4.7L PowerTech V8 Specific Topics 1 01-24-2011 09:47 AM
Whats gears? 02blue ram Dodge Ram 4x4 - Offroad Discussion 7 12-21-2010 10:27 PM
New Gears Red05Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 18 08-13-2010 10:18 PM
Gears dirtsurferus Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 3 08-28-2009 10:18 AM
