Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
MOPAR DECALS
Old 05-08-2011, 03:28 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:21
ND RAM is on a distinguished road
Default Anybody Change Their Own Oil???
When I got the truck home I crawled under it to see if changing my own oil is going to be easy.
Looks like the drain plug has no interference with dumping the oil. The filter looks pretty easy also (straight up and enough room to get at it).
Anybody have any problems changing the filter without dumping oil all over the truck and yourself? I've read somewhere to loosen it up, just slip a clear plastic bag over it and unscrew it till it drops in the bag. Anybody try this. Makes sense to me.
I have a long time before I need to change it. Only 700 miles on the truck so far. I'm going to change it at 3000 miles, then every 5000 miles using a Wix filter and Mobil 1 Synthetic. I've been doing that for years in all my new vehicles.
I go by the miles not what the computer thinks I should do.
Thanks for any info on what I should watch out for to make it nice and easy changing the filter.
18" Magnaflow, AVS Vent Visors, Black Rectangular Running Boards, Access Lorado Box Cover, Access Bed Mat, W.Tech Mud Flaps, W.Tech Tailgate Tech Liner, Hitch/Hook, Hitch/Ball and 35% Front Side Windows Tint.
Old 05-08-2011, 03:37 PM
Yup....the plastic bag trick works every time!
Old 05-08-2011, 03:38 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
I've always changed my own oil. I did my first change at 5,000kms. It's pretty easy and although I never tried the bag thing I think its a pretty good idea and should work. It was a bit messy once I got it loose. The only issue is that the factory filter is on real good, it took alot of effort to get it off. The oil from the engine does drain right into the catch pan and does not get onto anything underneath. Your choice of oil & filter sounds good, I use Amsoil 0W20 extended range and a UAP NAPA Gold (WIX) filter.
sales@revelperformance.com
Old 05-08-2011, 06:58 PM
16again's Avatar
16again 16again is offline
Trim Level: SLT Big Horn Edition
Rep:58
16again will become famous soon enough
Thanks to both you, and ND RAM for the tip, never heard of that. I'm gonna need to try that trick on my wife's Mustang. The RAM has lifetime oil changes from the dealer.
Old 05-09-2011, 12:33 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
I change my own oil. The plastic bag over the oil filter works, just make sure its pushed up high enough. Yes the stock filter and usually any time the dealer puts one on they are on there super tight, even with a filter wrench they can be a bear. I have also used a 1 gallon milk/water jug cut about 1 or 2 inches up from the bottom to catch the oil from the filter.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 05-09-2011, 12:40 PM
OregonTRX4's Avatar
OregonTRX4 OregonTRX4 is offline
Trim Level: 1500 TRX4
Rep:16
OregonTRX4 is on a distinguished road
How tight are you guys putting the filter back on? As tight as you can get it by hand? Also, is there a torque spec for the drain bolt? Thanks
Old 05-09-2011, 12:47 PM
MrPEZO's Avatar
Rep:38
I do mine as tight as I can get it by hand, I put it on put the drain plug in and then oil, then OCD kicks in and I go back under and make sure its all snugged up and nice and tight. Maybe RamTech could speak to the torque on the drain plug but I just put it on and tighten it down. The wife's Charger has a Fumato quick drain valve on it, so thats just a matter of open and close.
2012 Durango RT
Deleting Message - for oil change E220 Oil Change 6 11-23-2012 01:39 AM
oil change chrisisbored24 Oil Change 24 05-11-2011 06:43 PM
EVIC says Oil Change Needed? jimmiefan Oil Change 2 05-06-2011 01:28 PM
Oil Pan Gasket--Tough to Change?? Ivawoody 5.2L V8 Specific Topics 3 04-06-2011 08:50 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
