Old 05-08-2011, 04:21 PM
gator gator is offline
Vehicle: 2002 Ram 1500 4x4
Color: red
gator is on a distinguished road
Question AC electric fan check
I'm looking for to check it before I replace it. The AC blows cold while the truck is moving, but is intermittent warm/cold while not moving. The fan does not turn while parked with AC on and motor at operating temp. I checked the fuse and it's good. I'm guessing one of the two wires that go to the fan should be hot. Maybe do a probe test?
In an apparent unrelated situation, I was getting an antifreeze oder through the AC and thought the heater core was leaking , but I see there is coolant on the radiator reservoir tank and it seems the cap is bad. Is that likely?
Thank You
Old 05-08-2011, 05:22 PM
blackout's Avatar
blackout blackout is offline
Rep:16
blackout is on a distinguished road
I used a RC car battery, remove the fan and test it. My ram does the same thing
Old 05-08-2011, 09:51 PM
Color: red
Thanks for the feedback. I did the probe test and it is getting power, so the fan seems to be bad.
Does anyone have the fan removal procedure?
Old 05-08-2011, 11:26 PM
blackout's Avatar
Rep:16
great!!, youtube might be your best friend, search Dodge ram Ac, Dodge ram AC blower. I used this one..
Old 05-08-2011, 11:53 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
for helping - nice work Bkackout!
Old 05-09-2011, 10:50 AM
Color: red
Yes I appreciate it, there is a slight misunderstanding though. I probably wasn't clear enough. I was talking about the electric cooling fan by the AC radiator (by the battery under the hood). I looked on You Tube and wouldn't you know, I don't see anything on that. Maybe someone on here can give a general rundown???
Still curious about the radiator cap as well, do those go bad and allow coolant to leak out?
Thanks in advance!
Old 05-09-2011, 01:28 PM
blackout's Avatar
Rep:16
Youtube search" dodge ram Ac radiator fan" brought this up, there is 2 parts. Now about this (rad)cap, they do go bad the rubber seal tends to stiffen up over time I have replaced mine. Also the Rad cap has a certain temp when it opens/closes to allow coolant to and/from the reservoir. Then it could also be ceased and allow coolant to leak out the radiator.
Old 05-09-2011, 04:29 PM
Color: red
OK, excellent! I did try different word combos for the search, but apparently not that one. The cap does look OK (rubber not cracked or too stiff, spring seems good) that's why I was concerned maybe it was something else, like the system building too much pressure or something. I'll try a new one.
Thanks!
ac fan, radiator cap
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Electric Fan and MPG TedP Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 24 07-23-2011 12:29 PM
Electric Fan Options Ransport2011 2011 Dodge Ram Forum 1 04-28-2011 08:57 PM
Electric Fan Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 1 04-25-2011 11:13 PM
Electric Rad Fan panhead Dodge Ram General Discussion 10 04-01-2011 02:37 PM
