Old 05-12-2011, 08:51 AM
wannab's Avatar
wannab wannab is offline
Vehicle: 2011 Hemi sport
Trim Level: Sport QC.
wannab is on a distinguished road
I am going to jack up my truck this weekend and try that. I also was on concrete when they left marks.
2011 Black Sport Quad cab Ram, Magnaflow midpipe back exhaust, K+N intake.
Old 05-12-2011, 11:25 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Originally Posted by Blue Streak View Post
Esy way to see what you have, jack the rear up and spin the wheel. If both spin same direction you have a lsd.
Just dont forget to block the front wheels, and put the transmission in neutral
Two black marks is not always the best test..
I have a 10' Sport with open diff and 3.55's and can light up both tires from a dead stop on pavement too.
When I do a burnout at the drag strip I often get sideways right before staging
Old 05-13-2011, 07:54 AM
wannab's Avatar
My Titan had an open axle, and just left one mark every time.
Old 05-13-2011, 09:07 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Nissan's can burn out!?!? and multiple times!?!?
Sean
Old 05-13-2011, 09:12 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Originally Posted by 2011RamCC View Post
Can anobody here advise why Dodge, in their infinite wisdom, decided to only offer the LSD in the 3.92 gear option? I know that the traction control is the current technology, but I prefer to have the old school mechanical locking diff. My 2011 has the 3.55's, so obviously I didn't get the LSD. From what I can see, it was only offered as standard equipment in the Outdoorsman package, and maybe in the Sport package.
This seems to be one of the biggest discussions on the site. After living with the 3.55's for 20,000 miles and almost a year I've not had a situation where I was unable to get out. But I am thinking of adding an aftermarket locker to the RedRam10. Eaton is the direction I'm leaning toward.
Old 10-06-2011, 06:39 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
The ESP system is more that adequate for almost all situations. My Magnum SRT, believe it or not, came with an open diff- yet it would burn the tires bald if one desired.
I know the platforms are wildly different. That being said, I will probably end up adding an LSD.....
Old 10-06-2011, 07:38 PM
doug713's Avatar
doug713 doug713 is offline
Vehicle: 2011 Dodge Ram
Rep:33
doug713 is on a distinguished road
I also have the 355's with the open diff and can burn em both off, so my question is,,, what is the benefit of the limited slip other than better traction on slick surfaces (ie ice and snow)?? And correct me if I'm wrong, the mpg's shouldn't change much if any, right?
Old 10-06-2011, 07:50 PM
Rep:24
Exactly that- better traction on ice/snow and in the muddy/sandy stuff.
No change in mileage, either....
Old 10-06-2011, 08:03 PM
Rep:2616
even with an open differential, you get enough traction with your left side to get out of most circumstances
When your right wheel starts to spin in mud or snow, you can apply just enough BRAKE force to stop that wheel from spinning, while holding the brake pedal in that same position, apply the throttle slowly & give it just enough brake to keep that wheel from spinning. The rear differential will then Transfer traction to the left side & you can usually pull yourself out.
Try it for yourself, if you have an open differential, it works on both cars & trucks
Of course the LSD is better, you don't have to do the pedal dance,
Old 10-07-2011, 02:33 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Originally Posted by CHVYKLR View Post
you're right. that's new. the Ram site lets you select anti-spin differential with the 3.55s or 3.92s but it is removed if you select the 3.21s.
The 3.21's use a different housing and therefore cannot accept the LSD carrier (I looked into upgrading my 2009 w/ 3.21's). LSD is an option (and upgradable) for 3.55, 3.92 and 4.10 gears. I can't remember what it was going to cost though. I stopped listening when the bill got to more than $2500 to change my 3.21's over.
My Build Sheet, Do I have Limited Slip Diff al2ride 4.7L PowerTech V8 Specific Topics 7 11-03-2011 11:35 PM
Adding limited slip user zero 5.2L V8 Specific Topics 7 03-29-2010 12:46 PM
Limited slip trluby Newbie Checkin! 9 01-26-2010 10:46 PM
Ordered gears and limited slip! smartel 2009 Dodge Ram Forum 9 11-12-2009 01:33 AM
Limited slip differential buzzdoyle Dodge Ram General Discussion 2 12-19-2008 02:30 PM
