Old 10-07-2011, 02:41 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
It helps me in the rain and my engine specs are lower than 4G 5.7.
Old 07-17-2013, 05:27 PM
mdavis501 mdavis501 is offline
Vehicle: 2013 Dodge Longhorn
Trim Level: Longhorn
Color: Western Brown
mdavis501 is on a distinguished road
I'm looking at a 2013 Longhorn that is 3.21:1 and no anti-spin option vs a 3.92:1 that does have the option. Since both are 4WD, can't I put the truck into 4WD instead of doing that braking dance? Doesn't 4WD make the anti-spin not necessary as far as getting stuck? Or....and I'm afraid this is the real answer, if you have 4WD and no-LSD, does only 1 tire turn on your axle even in 4wd! I bet that is the answer.
Old 07-17-2013, 06:22 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
You answered your own question. No LSD = 1 wheel peel...at each axle if in 4wd.
Old 07-17-2013, 07:14 PM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
It's all about proportions.
4WD drives all 4 wheels despite what some post here.
Unlocked diffs are equal torque designs, so if the friction and weight under your tire are close: you get the same power to all 4 wheels.
Think of it this way: Neither opposing wheel can receive more torque from the vehicle than it's connected opposing wheel. So if one rear wheel is on asphalt, and the other is on ice, the one on asphalt can not receive any more torque than the one on ice. Normal 4WD works so well, because the vehicle is moving and the weight loading on the wheels is constantly changing, giving the 4 wheels the "average" of the friction limit.
Old 07-17-2013, 07:52 PM
CHVYKLR's Avatar
Rep:252
That's the point of lockers and LSDs...for when the friction and weight under the tires isn't close.
That has got to be the worst discription ever of an open diff and 4wd.
Old 07-17-2013, 08:19 PM
Vehicle: 2012 ram
Rep:117
I expect criticism from a post I might make in haste with bias or sarcasm from someone with a educated, legitimate counter view.
Since I wrote words of fact only, with no bias, or sarcasm, and you only try to attack what I wrote,
Please correct what I wrote that is not true.
Old 07-17-2013, 08:56 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Personally, I see no NEED for the LSD if you have 4x4.
With that said, I would take the 3.92 every time. Run FAR FAR away from the 3.21. I have had 3.55 and 3.92, I could not imagine how ungodly slow this thing would be with 3.21 and 4wd. holy hell.
Diesel Technician-PACCAR Inc.
Old 07-17-2013, 09:22 PM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:643
army, you might think differently if you lived in the snow/ice belt.
Old 07-17-2013, 09:27 PM
CHVYKLR's Avatar
Rep:252
I'll start over since I didn't realize I was attacking your post. My apologies for being harsh.
It is my understanding that when a vehicle with an open differnetial encounters a low traction surface, it directs power to the wheel with the least amount of traction. This results in the wheel on the low traction side spining while the opposite wheel with high traction receives little to no power. This is due to the low traction wheel not providing proper resistance to the side gear to spin the carrier and transfer power to the oppposing wheel. The carrier pinion gears (also known as spider gears) and the carrier simply rotate around the side gear with the most traction and nothing gets passed on.
No need for an LSD...have you ever been to the beach or done any off-roading. There have been many times driving thru fields in CO with my Dad where his 3rd Gen would've benefited from a limited slip. Instead we had to back up and use more speed which isn't always the best answer and you are just more susceptible to breakage.
Old 07-17-2013, 09:31 PM
Trim Level: sport
Color: green
Rep:643
are there any aftermarket lsd or lockers for our axles yet.
My Build Sheet, Do I have Limited Slip Diff al2ride 4.7L PowerTech V8 Specific Topics 7 11-03-2011 11:35 PM
Adding limited slip user zero 5.2L V8 Specific Topics 7 03-29-2010 12:46 PM
Limited slip trluby Newbie Checkin! 9 01-26-2010 10:46 PM
Ordered gears and limited slip! smartel 2009 Dodge Ram Forum 9 11-12-2009 01:33 AM
Limited slip differential buzzdoyle Dodge Ram General Discussion 2 12-19-2008 02:30 PM
