Old 05-10-2011, 07:44 AM
Mainecharge Mainecharge is offline
Vehicle: 2010 Ram Crew Cab 4x4
Mainecharge is on a distinguished road
Default Mildew smell when running air
I live in Maine and run the defroster from November thru April. I turned on the a/c last week and since then I keep getting a mildew smell. can anyone suggest a solution beyond not running the a/c?
Old 05-10-2011, 09:50 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
Most of the time the smell comes from people not running the a/c thru the winter, but you dont fit that situation..but regardless, you can simply buy Lysol and spray thru the outside vent.
Turn your a/c on full blast thru the dash vents, spray the entire can of lysol through the intake vent below the windshield. This will allow the lysol to get into the system and kill the bacteria that has set up.
There is a special product sold at auto parts stores, but I have found that lysol works just as well.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 05-10-2011, 10:35 AM
thewagon thewagon is offline
Vehicle: 2010 RAM 1500 QC BigHorn
Rep:35
thewagon is on a distinguished road
I found in the past from previous vehicles when I kept the "recirculate" activated all the time, the mildew smell would be at its worst. Always try to use the "fresh air" w/the A/C.
Old 05-10-2011, 11:36 AM
Thanks for the Lysol tip. I will try it and let you know how I make out.
Old 05-10-2011, 12:56 PM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
Make sure the drain from the evaporator box isn't clogged. You should see water dripping on the ground under the car when AC is running. If the drain is clogged you'll get standing water, mildew and if it's bad enough, water on the floor inside the car.
Cold Air Intake & Ram Air Hood? Stonednloaded Body & Interior 1 05-06-2011 03:12 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 11:26 PM
2001 Dodge Ram Air Conditioning westbygodtbone Heating & Cooling 1 05-03-2011 11:18 PM
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 11:31 PM
Headlights and running lights wont work at the same time, but work Indivdually??? komodo1982 Electrical 16 12-21-2009 08:53 PM
