Old 05-10-2011, 06:09 PM
Mr.Scarface Mr.Scarface is offline
Vehicle: 1996 Ram 1500
Mr.Scarface is on a distinguished road
Default High RPM during Acceleration.
1996 Ram 1500.
I am experience high RPMs while pushing the gas pedal, which make acceleration sluggish. Had a Check Engine light and a coolant leak. Fixed and flushed the coolant system. Change the Air Filter, which go rid of the engine light. Change the oil and oil filter. Still experience the High RPMs. Any ideas? Had a major tune-up in October 2009 and only has 7000 miles on it since then.
Old 05-10-2011, 06:45 PM
mikezram mikezram is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: off road
Color: green/silver
mikezram is on a distinguished road
well generally when you push the gas pedal the RPMs raise lol, can you be more specific? as in the rpms raise and you hardly go anywhere?
Old 05-10-2011, 09:36 PM
Sorry.
Correct. It seems the needle goes higher than before it will shift gears....and lowering the RPMs.
Old 05-10-2011, 10:03 PM
Without being right there to diagnose this, it's hard to pin it down. It may be electronic but I suspect your transmission is slipping.
How many miles on the truck? How many miles since you have changed out the fluid and filter in the trans?
Old 05-11-2011, 04:01 PM
122k miles.
6000-7000 since transmission service.
Shifting into 2nd gear seems to be the probelm..........it wont. Will Rev...high....and then maybe shift.
Old 05-12-2011, 01:10 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Was the trans service you had 6000-7000 miles ago the first one? or had it been done as recommended in maintenance schedule? Most of the time if you go way beyond the schedule with the transmission services and then perform them they have issues, and it is actually better to leave it alone. Was it a transmission flush (bad) or fluid/filter change (what you would want)? My dad had an '81 F100 he gave me with 220k miles on it, never had trans service just topped off fluid, I decided to change the fluid, never shifted after that automatically, I had to shift it manually with the gear shifter.
Sean
Old 05-15-2011, 08:25 PM
Well I thought it had a fluid change.....doesn't look like it. I changed the Filter and the fluid this weekend. No improvement. it will shift when the engine is cold. Once warm, it won't shift out of first unless it goes passed 3500.
Old 05-23-2011, 12:34 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
did you ever service or adjust the bands while doing the filter and fluid change??
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 05-26-2011, 02:30 AM
bsoja bsoja is offline
Vehicle: 2001 Dodge Ram 1500
Color: Orange
bsoja is on a distinguished road
i also had the same problem, and i was thinking about replacing the whole tranny all together, i was wondering if there was anyway i could run a a 3rd or 4th gen transmission.
ive also been looking for multiple ways to increase my power.
HID high and low Amp211 Custom Dodge Ram Interior and Exterior Lighting 8 10-12-2013 08:03 PM
Vibration or wobble in 4x4 high dankent 2011 Dodge Ram Forum 5 10-29-2011 05:44 PM
High Beam issues sonocativo Electrical 30 04-09-2011 02:37 PM
Axle ratio and acceleration question cptsopiens Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 4 04-05-2009 04:22 PM
