rattling noise rear end? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-10-2011, 06:31 PM
wickedpissahtruck's Avatar
wickedpissahtruck wickedpissahtruck is offline
Vehicle: 2014 Ram Laramie 4x4
Color: Maximum Steel Metallic 2 tone
Rep:23
wickedpissahtruck is on a distinguished road
Default rattling noise rear end?
Need some help here guys, hoping someone can steer me in the right direction. Have a rattling noise coming from my rear end (not that rear end!) when I drive over bumps. Not really a squeaking noisy, sounds like I've got some empty beer cans in the bed that are rattling around. Not the case though. I have nothing in the bed of my truck. Already had it to the dealer, but as is ALWAYS the case they couldn't replicate the sound. Doesn't happen all the time, so it's not consistent. Wanted to investigate myself. Anyone got any ideas on where I should start? Thanks for any input!
Old 05-10-2011, 06:48 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
those are always tough. Have you rolled underneath and given everything a good shake to try and eliminate the obvious? you could always try to tap different parts with a rubber mallet too...
Old 05-10-2011, 09:35 PM
Rep:23
yeah that was my next move to get down there and just start shaking some stuff around. Rattles/squeaks suck to try to figure what's causing them. Tough to simulate driving over a bump in your driveway. Was hoping someone might have had some past experience with this and could send me in the right direction.
Old 05-10-2011, 10:13 PM
PegCityTRX4 PegCityTRX4 is offline
Trim Level: CC TRX4
Rep:13
PegCityTRX4 is on a distinguished road
Do you have a drop in bed liner? I know mine rattles on the bumps if my bed is empty...
Old 05-10-2011, 10:17 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
maybe a heat shied rattling around
Old 05-10-2011, 11:12 PM
deepblue's Avatar
deepblue deepblue is offline
Trim Level: Quad Cab Sport
Rep:65
deepblue will become famous soon enough
If you have your tow hitch and ball in place in back, that will clank around over bumps.
Build Date: MDH:052720 [May 27th (Thursday), 8PM -- 2010]
2010 RAM Sport - Deep Water Blue, 3.92 Gears, Flowmaster 40 Series, Volant CAI w/PowerCore, BedRug, BakFlip F1, Bilstein B6 HDs
-cc
Old 05-10-2011, 11:21 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
That's the first thing to check
Second - Nest time you hear it rattle, lightly tap the brakes and see if it's only there with no brake applied. Although my 2010 Ram is fine, I have owned many trucks where the rear brake calipers rattled over bumps.....especially those 'lines' across the road.
brad
Interested in one of my mods?
Old 05-11-2011, 10:31 AM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Rep:16
jj ram is on a distinguished road
If you have a factory or after market plastic bed liner, that's what the noise is from.
My factory bedliner has done it from new, can especially hear it when the back slider window is open, sounds like a tin can rattle. I believe it's the middle of the bedliner bouncing off the metal bed at the back.
If you don't have a bedliner, I am not sure
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 05-11-2011, 04:20 PM
Rep:23
Very interesting, I definitely wasn't thinking it was the bedliner. I do have an aftermarket bedliner that I am not overly impressed with by the way. Wouldn't think plastic bouncing off the bed would make that rattling sound I'm hearing, but I will defer to you because you describe the noise I'm hearing. I'm going to go throw some weight in there now and take a spin. I'll be back in a few minutes with an update...
Old 05-11-2011, 05:06 PM
Rep:23
Man, I was hoping you were right!! Just threw a couple hundred pounds in the bed and still get the squeak!! Not the brakes either. Applied pressure to the brakes as I drove over the bumps and still heard the squeak. I don't have a ball on my hitch so that's out of the equation. How effing aggravating! Any one else got any ideas? Checked the heat shields too and didn't notice anything obvious.
97 Ram knocking noise from rear eddie7644 Suspension 5 03-17-2017 01:09 PM
Clicking noise in rear end HemiGTX Suspension 4 07-26-2016 06:06 AM
Help With "Whining" Noise From Rear??? GTR0419 5.2L V8 Specific Topics 5 02-07-2011 05:26 AM
Noise from rear end yankeefan4ever Suspension 0 04-07-2010 06:11 PM
Noise in Rear end 06QuadCab LD RAM - General Discussion 2 03-29-2009 06:17 AM
