Old 05-11-2011, 03:38 AM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Default Granite Alloy GA13 backspacing ?
Hey guys I've been looking at some new wheels and saw these XD Rockstar knock-offs and wondering about the backspacing/offset.
These are 18x9 with backspacing at 5.74" and offset of 20mm.
Compared to my stock 17s how will these set with some 33/12.50/18s?
Similar to stock? Inside the wheel wells? Stick out the wheel well?
This one has me all mixed up. I've got a small lift figured out but searching for something different on the wheels but these are the only backspacing options I've found.
Let me know what you think about the backspacing compared to stock. I'm guessing a little out the side but not much.
Old 05-11-2011, 06:17 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
That's gonna be pretty tight in the wheel well with that 20mm offset. Even with a leveling kit. I would look for something with at least a 0mm offset or even lower. Stock backspacing is right around 5 1/2" on you're truck, so the wheels themselves won't stick out much more then an 1/4" from stock. That's why I'm skeptical to the 12.5" tires.
Old 05-11-2011, 06:37 PM
Rammin's Avatar
Rep:44
That's kinda what I was thinking too.
I actually found a pic of a guy that has 35x12.50s and 17s on his 2wd and they just barely stick outside of the fenders but I have no idea if they rub or not inside.
Old 05-11-2011, 10:32 PM
a 20mm offset is just a bit too much positive offset with a 12.5 tire.
You'd want to be a +12 mm or less with that wide of a tire.
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Backspacing on an 04 stock 20" rim (2WD)? mikeoxlong Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 12-03-2010 02:25 PM
Lift Kit / Backspacing Issues... Silver05Ram Dodge Ram General Discussion 5 10-14-2010 12:04 PM
Stock 20" Wheel Dimensions - offset backspacing Digipenguin Dodge Ram Wheels And Tires 2 10-04-2010 10:41 PM
granite alloy wheels? sport200 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 05-10-2009 05:56 PM
