AC Issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 05-11-2011, 05:13 AM
Stevo's Avatar
Stevo Stevo is offline
Vehicle: 2000 Dodge Ram 1500
Color: Green
Rep:13
Stevo is on a distinguished road
Default AC Issue
Hey everyone, got a weird issue. when my AC is on and i accelerate it stops blowing out of the vents, then when i let off the gas it comes back. Solution? Truck is a 2000 Ram 1500, with 150k miles, Never had a problem with the AC and just noticed it doing this.
Old 05-11-2011, 01:04 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
You may have to get your A/C System Evacuated and Charged with new Refrigerant. I would recommend that they put new Oil in the Compressor as well, either it be ester or PAG.
Old 05-11-2011, 01:45 PM
Stevo's Avatar
Color: Green
Rep:13
Ill put that on the list of the other odd repairs left to make this thing 100% again. Isnt easy when your trying to paint it at the same time repair the odds and ends, ive put alot of man hours in this truck lol and even more to come
Old 05-11-2011, 02:00 PM
ramvan2500's Avatar
Rep:141
Trust me I understand, I am working on my ram also, I have wood inside so I been doing that wood work and I been fixing my transmission, had fixed my coolant leak last week I also have to fix my body rust and have the top of my ram van re clear coated after I do some touch up painting here and their I also have to fix my floor because it has bad rust and you could possibly fall through the floor. So yea and oh yes I have no A/C Either, I lost all pressure from it sitting for like 5 years or so and because their is no pressure the compressor won't kick on. I have my fair share of issue too. I just got this van and last month was the first time it ever moved in 5-7 years. I also have a busted window which was custom made so I have to hunt down another window.
Old 07-04-2011, 02:59 PM
Wild Willy Wild Willy is offline
Vehicle: 2010 Ram Crew Cab SLT
Wild Willy is on a distinguished road
My bet is you have a vacuum leak as a result of a broken vacuum line. Your symptoms are classic. It's usually a simple/cheap fix once you find the problem. Does anything not work, such as your cruise control? A broken vacuum line right at the cruise control was a notorious problem on mid to late (96/97/98) Rams Dunno about later models, but I'd put money on a broken vacuum line or bad check valve. Just my 2
The check valve is under the hood inline with the small hard (brittle/easily broken) vacuum line that runs through the firewall into the cab. One (of several) purposes of this check valve is to hold the AC/Defroster air damper shut during amild or normal acceleration (less than full throttle). Your complaint is a common one and a bad check valve or broken vacuum line will 99.9% of the time be the cause.
Old 07-04-2011, 07:11 PM
ramvan2500's Avatar
Rep:141
Good point, I wasn't really thinking of a vacuum only because usually you would feel a little rough idle but some people I guess are not quite as sensitive to feelings of those things as I am but anyways very good point.
Lazy/non-existent downshifts - anybody else with this issue? Turbovsix 2010 Dodge Ram Forum 18 05-20-2011 11:48 AM
Automatic Start Issue / Check Engine Light 07Ram 5.7L V8 Specific Topics 4 05-19-2011 06:46 PM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 10:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
AAC Interior Light issue Quiet Lunatic Custom Dodge Ram Interior and Exterior Lighting 8 06-01-2010 08:58 PM
