Old 05-11-2011, 01:47 PM
LeKy411's Avatar
LeKy411 LeKy411 is offline
Vehicle: 2011 Ram 1500
Color: Blue
Rep:100
LeKy411 will become famous soon enoughLeKy411 will become famous soon enough
Default Driver Door Creak
So I have my 2011 Ram Sport with 4,200 miles. I notices when the door sits closed for a while and then I open it, it makes a creaking noise. The noise stops after it is open a quarter of the way, but it is annoying.
Anyone have any idea. I hope its just a lubrication issue and nothing major. Anyone else notice this or have the same problem.
My list of issues keeps growing Grrrrrrrr.
Old 05-11-2011, 01:57 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
had the same thing in my 04 3500, all i can say is WD-40!
Old 05-11-2011, 02:46 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
try spraying alittle white litium grease on your door hinges,( avalible at most auto stores) this should be done a few times a year anyway....should remove your problem
So it is written ! So it shall be done!
Old 05-11-2011, 04:31 PM
Rep:2657
i have read that some people that have 4 doors, hardly ever open the rear 2 & they end up sticking closed
in the course of my business, i use all 4 doors almost daily
the dealer has kept them lubed, i check the lube after they apply it, sometimes they are a bit sloppy & it ends up on my pants or shirt
Old 05-11-2011, 05:38 PM
LeKy411's Avatar
Color: Blue
Rep:100
They must really be really packing it on your hinges. I got some white lithium spray. My hinges have no lube on them. It helped a little but a second application will be a must. I think is coming from the roller now that the paint has rubbed off on the metal that goes against the roller. I've never had a truck so I am not used to that kind of hinge design.
Old 07-29-2011, 09:31 AM
tat2dwiseguy's Avatar
tat2dwiseguy tat2dwiseguy is offline
Vehicle: 2012 RAM 1500 SPORT
Color: Deep Cherry Red Pearl
Rep:64
tat2dwiseguy will become famous soon enough
I have this problem in both front doors. The drivers door is worse and no matter how much or what type of lube is used, it doesn't go away. There is some slop in the hinge pin and roller as compared to the other doors, and the creak noise is amplified by the spring. I think the only resolution is to disassemble the whole hinge assembly and apply a good lube to the inside of the hinge and roller shafts. Dealer just keeps spraying tons of white lithium grease on it. My door jamb looks like a grease trap!
Old 07-29-2011, 09:58 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I had the 2 front doors and one rear door creak on mine. Tried all kinds of lubricants, and most would mask it for maybe a day. Finally a completely soaked the hinges in gear oil (made a huge mess) let it work itself in for a couple of days, then went to the local car wash and high pressure sprayed the hinges to get ride of the mess. It's been a few months now, and not a creak to be heard.
brad
Interested in one of my mods?
Old 07-29-2011, 10:26 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Same thing with mine, I tried white lithium grease, but need to apply it about once a month...for now I'll do that I don't know what else to do.
Sean
Old 07-29-2011, 10:29 AM
RELATIVELYQUIET RELATIVELYQUIET is offline
RELATIVELYQUIET is on a distinguished road
I have the same... Sounds like my truck is 20 years old. Disappointing
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Very uncomfortable driver seat 07' levi4me Dodge Ram General Discussion 12 03-03-2013 10:46 AM
Having trouble with my driver side low beam SapperRam1500 Custom Dodge Ram Interior and Exterior Lighting 3 02-15-2011 09:10 PM
Computer won't install device driver? wickedpissahtruck Diablo Predator Questions & Info! 5 11-08-2010 05:28 PM
Driver Headlight not working BiggBerger Custom Dodge Ram Interior and Exterior Lighting 3 11-02-2010 07:27 PM
