pinion bearings to change - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-11-2011, 06:02 PM
spockmckoy spockmckoy is offline
Vehicle: 2002 2500 ram
Trim Level: LT
Color: almond
Rep:19
spockmckoy is on a distinguished road
Question pinion bearings to change
Has anyone changed the pinion bearings on the rear dif of a 2002 2500 5.9 L gas; LT Dana 60 4:10 rear end? I'd like any advice/tips/special tools if you have. The reason I lifted up was due to major leak out pinion seal of rear dif. I have it up on jacks now and I found a bit of play up/down on the driveshaft. My 'theory' is that the seal failed because the hole oblonged due to the bearing failure of the pinion gear. I have been hearing a grinding noise in the rear end for some time now. I have the rear plate pulled, cleaned off all oil from gears and have inspected. I have the tranny in N and have hand rotated the gears to inspect all. All of the gears look fine. No obvious teeth missing/broken, etc. Any advice is welcome. Thanx in advance!!!
Old 05-11-2011, 11:45 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
There are plenty of how to videos on www.YouTube.com. Here is just one: http://m.youtube.com/index?desktop_u...?v=15zHpz6Zx8c
oil change warning revisited.... muskybait 2010 Dodge Ram Forum 11 05-26-2011 10:32 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 01:00 AM
Good Price for Complete Used Rear-end? marlin336 Suspension 7 03-09-2010 10:58 PM
Rear end confusion dirtsurferus Suspension 6 12-30-2009 09:25 AM
