16" wheels on an 02 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-11-2011, 08:19 PM
02Ram4.7 02Ram4.7 is offline
Vehicle: 02 Ram
02Ram4.7 is on a distinguished road
Default 16" wheels on an 02 1500
first off, I would like to say hello. Just joining the forum. I have had my Ram for a while now, and just not getting around to throwin money at it lol.
Anyways, to my question.. Does anybody know if you can fit a 16" wheel onto an 02 or newer truck (1500)?
I see some people say no, and some say yes. It has 20s on it now and I am wanting to go down to a 16.
Can it be done with spacers?
Thanks in advanced guys
Old 05-11-2011, 10:19 PM
It can be done. Just make sure you get the right offset, bolt pattern and backspace.
Here's some specs that should help ya:
Dodge Ram Wheel/Brake Specifications:
Wheel Specifications:
1994-1999 1500 2WD/4WD Aluminum Wheels
• Lug Pattern - 5 on 5.5", 1/2" bolt
• Rim Size - 16x7.0"
• Offset - +13.97mm
• Backspace - 5"
• Max Tire Size -
• 15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
Torque Spec
• 80-110 ft lbs (108-150 Nm) on 5 stud wheels
2000-2003 1500 2WD/4WD 17" Steel Wheels (Chrome or painted)
• Lug Pattern: 5 on 5 1/2
• Rim Size: 17x7"
• Fits 94 and up 1500 trucks
2000-2003 1500 2WD/4WD 17" Aluminum Wheels:
• Weight: 23.5 pounds
• Rim Size: 17x8"
• Actual width edge to edge: 9 1/16"
• Backspacing: 5 9/16".
• The space from the outside edge to the mounting surface (against the rotor) is 3 1/2".
• offset calculate: 1 1/32"
Old 05-11-2011, 10:27 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about using the link in my SIG to join us on the Newbie Checkin and posting a few photos of your truck?
I've read the smallest diameter wheel for GEN 2 and up are 17" to clear the brake calipers.
Old 05-12-2011, 06:37 PM
Vehicle: 02 Ram
lol thats what im sayin, some say yes, some say no. ill just have to try
Old 05-13-2011, 10:00 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
It might be able to be done, but I wouldn't risk it without a test fit first. Because while my truck was having exhaust work done, I was checking out the wheels up in the air, and even with 17's, there wasn't much room around the drums in the back and even less room around the calipers and rotors up front. My advice would be to go to a tire shop and see if the have any 16" wheels sitting around for you to try and put on real quick to see if they'll clear.
Old 05-13-2011, 11:44 AM
The only limiting factor here is finding a 16" wheel that will clear the brakes.
2nd gen wheels in 1st gen dodge? thebieri Dodge Ram Wheels And Tires 1 02-12-2011 02:17 AM
Pending ram 1500 purchase need some info! letsjet LD RAM - General Discussion 2 01-18-2011 03:52 PM
2010 1500 4x4 level kit, wheels and tires questions 1500minion Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 04-11-2010 02:07 AM
2007 1500 2WD 1500 Sport/want Bilsteins and coil spacers/rear blocks DanoHB Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-21-2010 10:59 PM
WTB-Dodge Ram 1500 Off-Road Wheels boostjunkie1 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 1 06-02-2009 06:56 PM
