Old 05-12-2011, 01:37 AM
sledman800 sledman800 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Longhorn
sledman800 is on a distinguished road
Default Engine runs hot while towing travel trailer
I have a 2010 1500 with 3.92 gears, i towed my 28' travel trailer and loaded it weighs about 7700 lbs, any time i hit the hills the engine temp would climb (250) along with the engine oil temp (250), the trans temp would be fine though. the ambient air temp was around 80, i checked the coolant level and all was good. I am just surprised at how easily the engine temp would climb as i had a 2006 ram that never even came close to heating up. i use the manual console shifter and kept the trans. in 4th gear has anyone else have something similar while towing?
Old 05-12-2011, 01:52 AM
Rep:2616
does it have
NHDP Heavy Duty Transmission Cooler
NMCP Heavy Duty Engine Cooling
if it just has the light duty radiator & transmission cooler, it will always over heat
Old 05-12-2011, 01:57 AM
yup i have the heavy duty tow package
Old 05-12-2011, 12:16 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
I towed our new 29 ft, 6500 lbs travel trailer this past weekend and my coolant temp didn't go over 204 f, but the outside air temp was around 60f. My trans never went over 183 f. This is with 3:55 rear end.
When I had my 04 Ram with a 4.7 V8, the temp used to run hot towing my 5000 lbs hybrid trailer on any incline or at interstate speeds. It would never overheat, but run in between half mark and HOT and sometime edge it's way to the HOT mark (sorry didn't accurate numbers at the time, just a dummy gage!)
I flushed the coolant, changed the thermo stat, had it at the dealer a couple times, nothing fixed it and was told, it just happens towing something pretty heavy.
I will have to watch it this summer to see if mine gets that hot, but perhaps it could be expected?
Where you in the tow/haul mode or just locked in on 4th? Tow/Haul works best for towing
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 05-12-2011, 03:09 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Have the same set-up as you and have towed the same weight without temps going over 235f. Are you using "tow haul" mode? I have found the rear end to be the weakest part of the truck so beware towing that weight. Make sure you have 75-140 gear lube in the differential (stock is 75-90) I also installed a Mag-hytec diff cover to keep things cooler.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 05-14-2011, 03:03 AM
I did not use tow haul as i like to shift manually, the transmission temp. is fine , it is the engine temp which would climb slowly.
Old 05-14-2011, 10:56 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
I think I would start by changing out your factory thermostat for a 180 degree thermostat. By having your temprature starting to regulate early would be your best defence I think.
Old 05-14-2011, 04:59 PM
kraftfahrer kraftfahrer is offline
kraftfahrer is on a distinguished road
I tow a trailer weighing about 4500 lbs and live in a mountainous region. I will have to use it this way starting next month (summer season) and am afraid it may overheat. Today I did a test drive with the trailer, driving for about half an hour at normal speeds (no highway!) with several uphill parts of the road. The engine temperature went up to about 205F, while the transmission temp went up to about 185F (normally mine is around 130F for regular use). But this was a short drive.
So my question is: will it stay that way (meaning it gets to that level and then it stays stable) or will it climb much more, for a 3-4 hours journey? I will drive such a journey in a few weeks.
My truck is a 2010 model 1500 Laramie with 3.92 axle ratio. Don't know about any heavy duty package, but it has trailer brake control and receiver hitch. I don't recall there being any special tow package, but I might be dead wrong, since I am in Europe, and not all options might be available here for import.
Can anyone advise?
Thanks
Old 05-14-2011, 05:02 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
Check your fan clutch. If you never heard it engage - sounds like a loud roar - it needs to be replaced. Common problem.
2004 Dodge Ram 2500 4X4 5.7
Old 05-14-2011, 05:16 PM
Rep:2616
the Tow/Haul selection makes your shifting points more aggressive if i am not mistaken
everything else should work as normal
If your engine temperature is climbing above where you want it to, SHUT OFF your A/C & open your windows
at least until you figure out another solution
What do I need to know about towing a travel trailer car421 Towing 17 08-10-2011 07:34 PM
Trailer Towing duck2456 2010 Dodge Ram Forum 4 05-02-2011 01:31 AM
Trailer towing Bruce E Towing 7 03-08-2011 09:59 PM
Engine runs backwards! Ramspeed 5.9L V8 Specific Topics 19 06-23-2010 01:48 AM
Engine runs hot 1970chevy 4.7L PowerTech V8 Specific Topics 8 09-28-2009 11:08 AM
