low fuel pressure at start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 05-12-2011, 06:54 PM
94muddigger 94muddigger is offline
Vehicle: 1994 dodge ram
Trim Level: laramie slt
Color: red
94muddigger is on a distinguished road
Question low fuel pressure at start
hey there, i have a 94 ram laramie slt 5.2L V8 and its has a little issue starting. to get it to start i have to crank it over twice with no reaction then the 3rd time it fires right up. i took it to my mechanic buddy an he checked the fuel pressure and it jumps to 10 when you turn the key then slowly climbs to 30. i think its supposed to just jump to 30, im thinkin its the fuel filter but i dunno, any ideas? thanks for any and all answers!
Old 05-12-2011, 09:58 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
i am having the same issue right now also. but you need a new fuel pump, well we do. the anti flow back valve built into the pump has kicked the bucket. go to a local LKQ U-PULL-IT and get a pump i think their 20 bucks.
Old 05-12-2011, 10:09 PM
Color: red
thats what i was thinkin, isnt the fuel pump in the gas tank though? i have a pull-a-part real close to me that ive used before but im not 100% sure how to get the fuel filter out an put it in my truck...
Old 05-12-2011, 10:28 PM
jbryan2's Avatar
jbryan2 jbryan2 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: 4x4
jbryan2 is on a distinguished road
Default Hard start
Sounds like you need a new fuel pump. Drop the tank and replace it. Its not that hard a job and pretty self explanatory when you get under it and look. Also, if you have the money just go to a local parts store and buy it new. Its about 150 and you will have a warranty on it.
Old 05-13-2011, 08:03 PM
ramvan2500's Avatar
Rep:141
If it's a 22Gal tank their should be two straps if it's 35 Gallon their should be 3 straps. If you remove the straps then the gas tank should fall off and screwed in on the top of the tank is the fuel pump. The filter is attached to the bottom of the pump sending unit assembly. The actual pump is inside of the sending unit which would be that thing you first pull out of the gas tank. Like the other guy said is you can buy one for around 200 or you can go to a pick and grab and get one for a few bucks in comparison. Make sure though the pump is from any dodge truck that has the same fuel tank capacity.
Old 05-15-2011, 05:24 PM
Color: red
thanx for all the help guys! ill check pull-a-part an let ya know how it goes
fuel filter, fuel pressure, start-up, starting issue, starting problem
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 08:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
