Old 05-12-2011, 11:15 PM
butlerjw78 butlerjw78 is offline
Vehicle: 2004 Dodge Ram
butlerjw78 is on a distinguished road
Default What size tires for 97 dodge ram 1500 4x4
What are the largest size tires I can go on my stock 1997 Dodge Ram 4x4?
I'm thinking of putting 285/75R16's on it. Can I pull this off without any rubbing on turns?
Thanks in Advance
-Jim
Old 05-12-2011, 11:23 PM
jbryan2's Avatar
jbryan2 jbryan2 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: 4x4
jbryan2 is on a distinguished road
Default Tires
Yes you can I have an 01 with 17x10 wheels with 295 70 17 and they barely scrubbed so I bought a leveling kit for 60 bucks. You shoud be fine. If it does scrub it will not be much at all
Old 05-12-2011, 11:40 PM
I just noticed I posted this in the incorrect Gen forum, for that I apologize....
Thanks for the reply... I may go that route also with the 295's
Old 05-13-2011, 03:12 AM
984wdram 984wdram is offline
Vehicle: 1998 dodge ram
Color: deep amythest and silver mist
984wdram is on a distinguished road
i had 315-75-16's on my 98 4x4 factory, just had a thin wheel spacer and only rubbing issue i hadwas on the front link bars. i found out that if the steerin wheel was completely upside dwn, it wouldnt rub t all. theres not that much more turning radius between the wheel being upside down and fully locked.
Old 05-13-2011, 06:32 PM
Moved this to Dodge Ram Tires and Wheels.
I think you can go a bit wider but a 75 aspect ratio tire is gonna be a close fit.
Old 05-14-2011, 01:13 AM
close fit, yes...but they did fit. with a stock rim they would only rub at full lock. put a set of 16x8 rims on there and kept the thin spacer and now have no rub.
Will Dodge Ram 1500 2010 Wheels and Tires fit a 1998 Dodge Ram 1500? koalatyman Dodge Ram Wheels And Tires 1 04-14-2011 11:38 PM
long lasting tires for dodge ram 1500 Adam Haeselin Newbie Checkin! 11 04-03-2011 05:16 PM
Dodge 1500 in NM rodanst6 Newbie Checkin! 13 03-23-2011 05:31 PM
NEED HELP ON TIRES 2006 Dodge Ram 1500 Qwd JBSPartans05 Dodge Ram Wheels And Tires 5 04-16-2010 12:10 PM
2004 Dodge Ram 1500 ramit04 Dodge Ram For Sale - Used Dodge Trucks 3 03-10-2010 11:48 PM
