A little help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-13-2011, 07:28 PM
keegles's Avatar
keegles keegles is offline
Vehicle: 1998 dodge 1500
Color: driftwood
Rep:19
keegles is on a distinguished road
Default A little help
I need a little help. My truck won't idle. Iv replaced plugs, plug wires, did a spark test, tested all injectors, replaced idle air control valve, and it still won't run. It starts if it has sat for a few hours, but it won't idle. And once it dies it won't start again. It makes a loud sucking sound. It's a 98 ram. 318. I don't get around a computer very often so if someone could text me or call me and give me some direction it would be very appreciated. 760 793 6979. If I don't answer leave a voicemail. Thank you.
Old 05-13-2011, 08:42 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
What RPM does it run at if it won't idle?
Old 05-13-2011, 08:48 PM
jbryan2's Avatar
jbryan2 jbryan2 is offline
Vehicle: 2001 Dodge Ram 1500 4x4
Trim Level: 4x4
jbryan2 is on a distinguished road
A sucking noise would be a large vacuum leak to me. Try spraying starting fluid around the intake and see if it revs up. Is the check engine light coming on. If so get that checked it will tell you info about what the computer is seeing a problem with. Also, could be a throttle position sensor. Really need more information to help you on this one.
Old 05-14-2011, 03:07 AM
keegles's Avatar
Color: driftwood
Rep:19
The sucking sound is coming from inside the throttle body, were the idle air control valve is. Iv replaced every. Thing that has thrown a code. My truck is a base modle so no tach, the truck will not idle on it's own. I have to hold the throttle open a little to keep it running.
Old 05-15-2011, 08:46 PM
Joe779 Joe779 is offline
Vehicle: 2000 Dodge Ram 4x4
Color: Blue
Joe779 is on a distinguished road
Hey guy's, It almost sounds like an EGR valve stuck open, I can't remember what year they stop putting them on the V8 engines. If one is open engine wont idle or may not even start , but push on the gas pedal a little and it will start and run!
At idle it should be closed and and wot( wide open throttle) closed also.
The intake will get hot to the touch really quick while engine is running, hotter than the engine coolant. Check the back of the intake and see if you have one.
Old 05-15-2011, 09:01 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
possible crank sensor
Old 05-15-2011, 09:31 PM
autometrics's Avatar
autometrics autometrics is offline
Vehicle: 2005 Ram 1500
Rep:23
autometrics is on a distinguished road
sounds like a bad intake gasket.
Old 05-30-2011, 10:20 PM
keegles's Avatar
Color: driftwood
Rep:19
thanks. i will check those as soon as i get my truck out here, (recently moved to arizona and had to leave my truck in california)
