Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 05-13-2011, 09:14 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Default Weird WOT shifting
Ever since about 6 months after I got my truck it does this weird thing at WOT going from like 2nd to 3rd gear. It won't always do it though. But it'll get up all the way to 5200 rpms and then hesitates to shift into the next gear for like 3 or 4 seconds and while it's hesitating the engine just keeps hitting the rev limiter and it sounds really odd. I'm not getting any codes or any other shifting problems, just WOT from 2nd to 3rd. I try not to run it at WOT anymore just because it's a little embarrassing driving around and my damn truck doesn't wanna shift. Any help is greatly appreciated.
Old 05-16-2011, 12:32 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
JC, I don't have an answer for you so, it's time to .........*
______________________________ this back to the top!
Old 05-16-2011, 02:08 AM
Rep:2642
you have 2 choices
manually shift through the gears starting in 2nd gear
or put it in Tow Haul mode
try both methods
otherwise get a tuner
Old 05-16-2011, 03:46 AM
jcasey10's Avatar
Rep:869
you have 2 choices
try both methods
It still does it with the O/D off, and I can only go 1, 2, and then drive. I have the column shifter. And there are no tuners to change shift points on the 5.9
jcasey10's Avatar
Rep:869
Thanks bud
Old 05-19-2011, 03:55 AM
SRTB8ked's Avatar
SRTB8ked SRTB8ked is offline
Vehicle: 1999 Dodge Ram
SRTB8ked is on a distinguished road
my '99 5.2 sport does the same thing, clean shift from 1-2 but 2-3 hits rev limiter and then shifts into low rpms to 3rd gear
Old 05-19-2011, 04:34 AM
jcasey10's Avatar
Rep:869
I don't really understand it. I did a bunch of runs here just a minute ago after work, and I couldn't get it to do it. Oh well
Old 05-20-2011, 06:55 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Cool
JC its happened to me a few times too. I can still hear it in my head "vrrrrunnn vrrrrunnn vrrrrunnn vrrrrunnn vrrrrunnn" kinda makes you wanna ease of the pedal. Have you tried adjusting your kick down cable? I experimented with mine a little and its been fine about 3 weeks now. I'm not 100% sure that'll fix it. Now on my ram I had it adjusted to hold my gears longer with a hard shift. I'm assuming when its reaching for 3rd gear it couldn't reach past the rev limiter to grab it so I tweaked the kick down to shift a bit sooner hehehe I'm just guesstimating and troubleshooting over here since I wasn't able to find an answer I took the matter into my own hands, it seems to be working so far. Oh well time will tell.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 05-20-2011, 08:56 AM
jcasey10's Avatar
Rep:869
Ahhhh....Just seeing how you spelled it out like that reminds me of how it does that. Sends chills down my spine lol. I'm not sure what the kick down cable is?..
Old 05-20-2011, 11:57 AM
RAMING IT's Avatar
Rep:65
Post
Here you go bud
http://viewer.zoho.com/docs/f3a9cb
trans shifting weird Reed44 5.9L V8 Specific Topics 1 03-31-2011 08:18 PM
'01 Dodge Ram 4wd shifting problem CloneSaw Cummins Diesel Specific Topics 2 02-10-2011 12:25 PM
2010 hemi towing and shifting? Needs to quit Zack Birge Towing 26 01-19-2011 08:31 AM
shifting gears... farmhouse66 5.7L (345 cu in) HEMI V8 Specific Topics 6 09-23-2010 06:18 PM
Manual shifting question? Ray 2010 Dodge Ram Forum 6 03-12-2010 11:43 AM
