Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 07-04-2011, 10:42 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Thats an option Ima try anyways cuz its about that time.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 07-10-2011, 09:04 AM
Redlongbed's Avatar
Redlongbed Redlongbed is offline
Vehicle: 2002 Dodge Ram 1500
Redlongbed is on a distinguished road
Originally Posted by dodgemagnum5.9 View Post
I had a 98 that did the same thing. Only had less than 30k miles. I changed the tranny fluid and filter just because it was routine maintenance I knew the dealership would charge me for doing if it had not been done yet (still under warranty). That fixed the problem. Never had any more prob. after that.
I changed my filter and fluid not too long ago and mine still does it...
Old 07-10-2011, 01:14 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Trim Level: SLT Quad Cab
Rep:869
Mine had the filter changed and the fluid flushed about 5000 miles ago and it still does it. Not quite as frequent though. I honestly think it has to be something electrical that Dodge may have did not tune quite right. It's like the trucks computer can't shift fast enough or something.
Old 07-30-2011, 06:03 PM
cabnfevr's Avatar
cabnfevr cabnfevr is offline
Vehicle: 02' RAM 1500 SPORT
Color: blk
cabnfevr is on a distinguished road
Had a sim problem with my 02' 1500 4x4. Was driving everything was fine then truck just bogged out and would'nt shift after that. Wound up being a sensor in the trans pan. ( I think it was called a speed temp sensor regulator ) not pos on the name was over a year ago. Real easy to change just messy. It's a 15 min repair. Step 1.drain trans fluid 2. drop the pan 3. remove the trans filter 4. unplug sensor remove bolt and replace sensor & replug. Install new filter pan gasket & replace pan and mopar spec fluid. The light cleard an truck was back to normal. I think the part was about $80 bucks. No spec tools just a ratchet and screw driver. Hope this helps.
Old 07-30-2011, 06:43 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I was going to suggest a tuner, but they don't have a lot of choices for your engine. I hope you figure it out man!
Dillon-aka, The Little Kid
Old 08-03-2011, 01:06 AM
soco native's Avatar
soco native soco native is offline
Vehicle: 02 ram 1500 5.9
Trim Level: slt sport package
Color: BLACK
soco native is on a distinguished road
any one notice all the posts were by guys with the 02's!
TWIN TURBO IN THE WORKS!!!
Built for boost short block by PIE, forged internals, PIE by JE blower pistons, Edlebrock MAX port heads, PIE turbo cam, Comp Turbos, JGS waste gate and BOV, SCT tuned by PIE and DIY 304 SS sch30 pipe turbo manifolds.
Old 08-03-2011, 01:45 AM
White Lightening's Avatar
White Lightening White Lightening is offline
Vehicle: 2001 Dodge Ram Quad Cab 4x4
Rep:38
White Lightening is on a distinguished road
my '01 1500 does the same thing but it was rebuilt ... has under 10K on it everything is NEW was at the test and tune on thursday ( for the first time this year for me and the new tranny)... found out (thank you ramvan) that 1-2 shift is hydraulic and 3-4(o/d) is electronic. So im thinking there has to be a certin pressure for the computer to accept the shift into 3rd. id like to get this issue solved before my 408 project starts cause thats how im building it is threw race funds
Drive It Like You Stole It ... Yeeeehaaaa !!!! 01 Ram or the 03 Neon Sport 5 spd
2010 hemi towing and shifting? Needs to quit Zack Birge Towing 27 08-27-2016 09:22 PM
trans shifting weird Reed44 5.9L V8 Specific Topics 1 03-31-2011 08:18 PM
'01 Dodge Ram 4wd shifting problem CloneSaw Cummins Diesel Specific Topics 2 02-10-2011 01:25 PM
shifting gears... farmhouse66 5.7L (345 cu in) HEMI V8 Specific Topics 6 09-23-2010 06:18 PM
Manual shifting question? Ray 2010 Dodge Ram Forum 6 03-12-2010 12:43 PM
