ZDOG
Old 08-22-2011, 10:28 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
great write-up. i installed a 300-236 on mine a couple of weeks ago. happy with the results. jegs.com still has them on sale for $194. you'll re-use your factory tube but it wasn't worth $150 plus to me.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 08-22-2011, 10:41 PM
WSpeedRacerZ28's Avatar
WSpeedRacerZ28 WSpeedRacerZ28 is offline
Vehicle: 2015 Dodge Ram 1500
WSpeedRacerZ28 is on a distinguished road
With the airraid, k&n, volant, or other CAI's (I know they are each a bit different), has anyone used a throttle body spacer such as the AFE along with the CAI? My question is will the intake tube from the throttle body be hitting the hood when it closes since it will sit higher than just the throttle body without the spacer?
Old 08-22-2011, 10:52 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The tube make a big difference, the wrinkles really hurt airflow to the throttle body. The tube doesn't hit the hood and don't waste your money on a TB spacer....I have yet to read one review where it was positive!
Old 10-26-2011, 05:05 AM
BJPUSMC's Avatar
BJPUSMC BJPUSMC is offline
Vehicle: 2013 Ram 2500 Mega Cab 4x4
Color: Deep Cherry Red/ Silver
BJPUSMC is on a distinguished road
Great write up. I was leaning towards the Volant for mine but now might have to reconsider. I especially appreciate the description of the added engine noise. Any one know if the Volants have the same effect on sound?
2013 Ram 2500 Laramie Mega Cab 4x4,
6.7L H.O. Cummins Turbo Diesel
USMC Pilot
Old 10-27-2011, 07:44 PM
old amateur's Avatar
old amateur old amateur is offline
Vehicle: 2011 Ram 1500 Crew
Color: red
old amateur is on a distinguished road
Good job on the write up. I just installed a K&N 63 Series on my 2011 Ram 4X4 (5.7). Your description of the installation and parts sound very familiar!!
I too checked mileage in both City and Highway driving prior to installation and just returned from my Highway test. I saw an average increase of 3mpg (so far).
I found I probably didn't need to cut the stock air return tube thing that runs from the valve cover to the air intake tube (don't recall what it's actual name is). The supplied tube was much too flexible and crimped shut when I installed it as per instructions. I ended up using the left over stock piece and joined the old and new back together using a piece of the more supple supplied tube.
First drive showed improved throttle response and a noticable change in sound when you put your foot into it. You can also hear the air being sucked in under the hood.
I was also able to quite easily light up the rear tires though to be honest, that's not something I really tried to do in stock form.
One more thing, I mentioned in another thread how a performance shop sales guy told me metal CAI tubes tend to get quite hot thus defeating the purpose of a Cold Air Intake. After driving the truck for a half hour I checked the CAI tube. It was actually cold!! Everything else under the hood was pretty damn hot. I have no idea what material K&N used but it definately works.
cheers,
Old 11-05-2011, 08:53 PM
Color: red
Picture of the K&N 63 series I installed.
Old 06-14-2014, 06:18 PM
sixxgunner's Avatar
sixxgunner sixxgunner is offline
Vehicle: 2011 Ram 1500 Big Horn
Color: Brilliant Black Crystal Pearlcoat
Rep:17
sixxgunner is on a distinguished road
Awesome write up. Thanks for the needed info!
