Old 05-14-2011, 12:52 PM
Noggles Noggles is offline
Vehicle: 2016 Ram 1500 Crew Cab
Noggles is on a distinguished road
Default AFE PRO 5 Dry Intake System 11 Ram Sport
Hey guys,
I put this intake on my '11 Ram 1500 Sport Quad Cab ...
http://wwww.afepower.com/shop/detail...632&print=true
After 2 tanks of gas, my gas mileage went from 15.1 to 13.4 mpg.
Moreover, it's loud as hell ... a lot of cab noise when you accelerate.
Needless, to say, I'm not thrilled. I called a local performance parts shop and they told me I'm driving it harder, which is BS because I drive the truck the same everywhere I go ... not aggressive at all. Truck has about 3K miles.
Any thoughts? I'm thinking about putting the stock intake back on and selling it.
Old 05-14-2011, 01:30 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Pull the negative battery cable off for 30 minutes...this resets the computer and lets the truck "learn" the new intake. See how it is after that, then decide!
Old 05-14-2011, 02:28 PM
Can't do anything about the noise but that ^^^^ is a very good suggestion.
Old 05-14-2011, 02:44 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
let the pcm learn the new airflow rate..mileage should get better...do you have an exhaust to go with it?
Old 05-14-2011, 03:45 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
try the above suggestion then run a couple of tanks and record what you get. if you think you are still coming up short reinstall the factory box and run a few more tanks to compare.
Old 05-14-2011, 06:15 PM
Nope, no exhaust to go with it.
I reinstalled the stock air intake. The truck is running much smoother.
I took the ARE intake back. I think I can use the $300 better elsewhere!
Thanks everyone!
Old 05-18-2011, 12:29 AM
916Timmy's Avatar
Rep:1443
That will work too!!!!
What is the best cold air intake system? HEMIHP 5.7L (345 cu in) HEMI V8 Specific Topics 13 01-10-2013 03:48 AM
K&N System Intake Hemi Power 4x4 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 01-18-2011 12:01 PM
S&B cold air intake system 2010 Hemi Chrisbadram 2010 Dodge Ram Forum 3 01-02-2011 06:42 PM
Oil Change Indicator System '09 And Newer RamTech Dodge Ram Knowledge Base 9 10-03-2010 02:00 AM
Multiple Displacement System (MDS) GTyankee Dodge Ram General Discussion 51 04-20-2010 05:40 PM
