Old 05-14-2011, 02:35 PM
fdny37 fdny37 is offline
Vehicle: 2011 Dodge Ram
fdny37 is on a distinguished road
Default Warning!!!!!
I have this posted in the recall section but I don't think many people gave it a look.
I think they need a recall for the recall. I just had my truck serviced for this recall and when I got the truck home I looked underneath and the plug, valve or whatever it's called on the differential cover was gone. So right now I'm waiting for the flat bed to tow the truck back to the dealer. Here are some pictures of the gaping hole on the diff cover. There are no threads on that hole so I'm assuming that there is supposed to be some sort of plug or pressure relief valve. I don't know wtf happened but whatever did shouldn't have.
Old 05-14-2011, 02:39 PM
Interesting. Have you talked to the dealer?
Old 05-14-2011, 02:43 PM
luket57's Avatar
luket57 luket57 is offline
Rep:14
luket57 is on a distinguished road
Good to know. Just purchased mine a week ago. I'll have to look underneath it when I get home.
Old 05-14-2011, 03:13 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I just looked under mine and yeah, there is a big plug there.
Looks like your dealer just screwed up and didn't put the plug in.
It could be worse, I had a friend that went for an oil change and they told him it was done.
He made it about 100 yards before they realized they didn't put any oil in after draining it.
His truck was totalled....
Old 05-14-2011, 04:13 PM
ronnie4946's Avatar
ronnie4946 ronnie4946 is offline
Vehicle: 2014 Dodge Ram
ronnie4946 is on a distinguished road
Had my recall done, they changed the cover. The new cover has a cheap rubber plug installed. No threaded plug , just a rubber plug. I hope it keeps water out.
Old 05-14-2011, 04:16 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Real Interesting - I have a "Get In Here" letter for two recalls - so I guess I'll set up an appointment.
Old 05-14-2011, 04:30 PM
Rep:2664
the hole just is suppose to have a rubber or plastic push in plug in it
they went as cheap as possible to keep costs down
they should have made a cover with a threaded fill/inspection hole & a threaded drain hole w/ a threaded magnetic drain plug, but that would have cost them more.
it would look like this
http://stores.hi-potek.com/-strse-2/...ar-/Detail.bok
Old 05-14-2011, 04:44 PM
RAMTX's Avatar
RAMTX RAMTX is offline
Vehicle: 2015 Dodge Ram Crew Cab 4X4
Trim Level: Lone Star
Color: Bright Silver Metalic
Rep:110
RAMTX will become famous soon enoughRAMTX will become famous soon enough
wow, thanks for warning us, I am still waiting on parts to perform the K36 recall from my local dealer. I will keep a eye on it after it get done. REP POINTS FOR THAT!!!!
__________________________________________________ ___________________
__________________________________________________ _____________________ K&N drop in Air Filter - Tonno Pro Tri-Fold Bed Cover
Old 05-14-2011, 09:26 PM
GotHemi GotHemi is offline
Vehicle: 2011 Dodge Ram Laramie
Color: Red/Tan
GotHemi is on a distinguished road
Thank you for the warning, when/if my dealer gets the parts in i will be sure to look before i drive it off of the lot.
WARNING LIGHT BLINKING / 2009 Laramie Jake2 2009 Dodge Ram Forum 35 05-24-2011 10:03 PM
WARNING: Veterans Affairs Services (VAS) RootBeer Military 2 12-05-2010 11:49 PM
Activating Side Heated Mirrors & Radio Traffic Warning Sign removal? RammD Dodge Ram General Discussion 2 07-31-2010 01:28 PM
Seatbelt warning beeper from Hell. lt173 2010 Dodge Ram Forum 7 07-23-2010 11:47 PM
Please Help! Problems with my 07 Ram 1500 Warning Chime hemijames Newbie Checkin! 16 02-06-2010 08:17 PM
