Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 05-14-2011, 03:02 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Default Any way to fix this??
So last year during hunting season I was loading a large cooler in the back of the truck and I ended up scratching the heck out of one of the plastic door panels...
Is there any way to repair this? I know I can't make it good as new but I think back to those old vinyl repair kits they used to hawk on TV to fix recliners & stuff, but can't find anything.
Thanks for any suggestions!
Old 05-14-2011, 03:25 PM
I saw the guys on Trucks take a heat gun to a panel that looked like this and they were able to melt the raised ridges and scratches right back into place.
Old 05-14-2011, 03:41 PM
Rep:2657
excerpts taken from websites
1) use a cleaner first and see how bad it is. you can use a plastic scratch remover or even toothpaste to sort of dull the scratch. but be careful no to over do it you will start to make sort of a shiny area that will look worse than the scratch. you can also try using a hair drier to slightly raise heat of vinyl and try and rub out the scratch. vinyl will take a lot of heat so dont be to afraid just dont melt the glue holding vinyl to the door panel. good luck and let us know the results.
2) You might try Poorboys Natural Look Dressing.
I had a similar type scratch and it did a nice job of blending it with the surrounding area.
Poorboys World Products
Poorboy’s has made a name around the show circuit for fantastic products at great prices! Its ever-growing popularity is due to word-of-mouth testimonies from novice detailers through auto enthusiasts about the brilliant results no matter what your level of expertise. You’re going to love Poorboy’s!
2 B)
Natural Look is water based but it seems to last better than others I have used.
I have also used the Prestone vinyl repair kit to fix some scratches and tears.
It works as long as you get the color matched just right. I also use a propane torch to heat the metal ironing tool instead of an electric iron because it is faster and the product seems to respond better to the higher heat. You don't want the tool so hot that it burns the paper though.
2 C) Do nothing... As you heat the area, the scratch will smooth itself out. Keep the gun moving, about 2-3 inches away from the pannel, concentrating on the scratch. What happens is as the plastic heats, the rough edges or the scratch get soft and, as I mentioned, smooth themselves out. Let it cool without touching it and procede as normal with your chosen dressing. I've had to use this method on many pre-production mock-ups and prototypes.
3) Meguiar's Inc. Technical Specialist typed
Ultimate Protectant probably does a better job of this than anything else. Obviously you can't really polish out a scratch on a textured vinyl surface, but you can conceal them a bit. UP seems to do a very good job of this.
Good Luck
Old 05-14-2011, 05:20 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
Great suggestions, thanks guy!
Old 05-14-2011, 06:31 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Yeah!!! I have a few little scratches by the glove box I would LOVE to fix! Let me know how it works so I can try it too!!!
Old 05-14-2011, 10:19 PM
Amdukias's Avatar
Amdukias Amdukias is offline
Vehicle: 2011 Ram
Trim Level: Sport Crew Cab 4X4
Color: Deepwater Blue Pearl
Rep:26
Amdukias is on a distinguished road
Nice, love to see someone mention Poorboys, my favorite detailing brand.
If a man talks in a forest, and there is no woman there to hear him, .... is he still wrong?
