Old 05-14-2011, 03:20 PM
Tmac Tmac is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Crew Cab 4x4 Laramie
Tmac is on a distinguished road
Default 20x10 or 20x9?
Posted this under the sticky and now reposting;
I have an 09 1500 Laramie. 2" front/1.5" rear leveling kit going in this week. I have Dick Cepek 35"x12.5" tires and am trying to determine the best wheels.
I like the look of the Eagle Alloy 064. They are 20x10 with 4.64" bs and a -21 offset. The garage that's doing the work is concerned they will rub the fender wells. They are suggesting a 20x9 wheel with bs closer to 5" for better fit.
My alternative is the Eagle Alloy 079. They are 20x9 with 4.64" bs and a -12 offset.
Any comments on these fitting or rubbing would be appreciated.
Old 05-14-2011, 06:33 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Ok I have 20x10's and love them!! But they might rub for real.
Old 05-14-2011, 09:21 PM
ScatPak07's Avatar
Rep:970
I would go with a 10" wide rim so the tire don't balloon as much. That will make the tire look better and also make it a little bigger. The -21 offset is quite a bit of offset but that should be good. I have -18 offset which is not too far off and I had 35x13.5 tires and they were good with a leveling kit. I did have to trim the bottom corner of the bumpe and fender well, but thats cause they were a 13.5 wide tire. I would def go with the 10" with -21 offset.
Old 05-14-2011, 09:32 PM
Rep:463
Ya mine are -18's also.
Old 05-17-2011, 04:46 PM
bigredreiter's Avatar
bigredreiter bigredreiter is offline
Vehicle: 2007 Dodge Ram
bigredreiter is on a distinguished road
I've got the Bilstein 2.5" level on my '07. I tried to fit 20"x10" with -24mm offset and 35"x12.5" and they rubbed the fender pretty bad.
20x10 or 20x8.5 KMC rockstars on 5" Lift? sinistersix Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 01-02-2013 06:44 PM
My new 20x9 MOPAR chrome wheels charlie3133 Dodge Ram Wheels And Tires 12 03-07-2011 01:39 AM
Center Caps and 20x8 tires on 20x9 rims? Scjon03 Dodge Ram Wheels And Tires 1 12-05-2010 06:48 PM
2010 2wd with 305/55/20 20x9 -10 offset? cyberpine 2010 Dodge Ram Forum 12 10-20-2010 12:06 PM
20x9 Eagle alloy 079 ehoeft Dodge Ram Wheels And Tires 20 05-05-2010 07:26 PM
