ZDOG
Old 05-14-2011, 03:43 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Default Please explain MDS
Can you explain how I disable the MDS and then re-enable it? Thanks.
Old 05-14-2011, 03:56 PM
Rep:2720
best way to explain it i believe is
a V-8 has 8 cylinders, MDS when active runs the engine on 4 cylinders, without harming the engine & it is suppose to save gas
to simplify things
your transmission has 5 gears & 5th overdrive
MDS ONLY kicks in while the transmission is in 5th overdrive & you are on flat ground or going down hill
If you don't want MDS to kick in, just make the single shift down to where you see a 5 light up on your dash readout.
5th overdrive will not display any number on your dash readout
that is an over simplified explanation, but, it is the easiest way to explain it
Old 05-14-2011, 08:15 PM
ND RAM ND RAM is offline
Vehicle: 2011 Dodge 1500 Crew Cab 4X4
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:21
ND RAM is on a distinguished road
That explains why I'm turning over 2200 rpm in 5th. at 75 mph.
I ALWAYS use the manual shift when bopping around town.
Tonight when I went out on the highway I had it in 5th. gear.
So I WASN'T in "overdrive".
Do I just move the shifter one more notch to the right to turn off the 5th. gear light?
I'm still learning stuff from you folks.
Old 05-14-2011, 08:34 PM
Rep:2720
yes, 1 more to the right & you will see the light with the 5 go out
that is when the computer takes over & allows the vehicle to go into MDS mode, when there is no need for power, such as climbing a hill it will quickly shift into 5th or kick into MDS mode on flatter terrain, most of the time you won't even know that it shifted or changed modes.
Sometimes when climbing a steeper hill, you may notice your speed dropping when you are using cruise control, then the auto pilots speed sensor sends a signal to the computer(s) & tells them that the speed is below what you set it at. At this point if the setting gets say below 7 or 8 miles an hour below your chosen setting, you WILL feel it kicking out of MDS & shifting down & it may surprise you with the power burst
Old 05-14-2011, 09:44 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
http://www.ramforumz.com/showthread.php?t=47443
Old 05-14-2011, 10:08 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
http://www.ramforumz.com/showthread.php?t=81791
Old 05-15-2011, 04:54 PM
mriboy mriboy is offline
Vehicle: 2012 Ram 2500 Outdoorsman
Trim Level: Outdoorsman
Rep:22
mriboy is on a distinguished road
Glad I found this site such great info here
Airaid CAI , Fastman 85mm TB, Magnaflow 18", Magnaflow Y, JBA Shorties, Billet Tech catch can.
When the MDS Functions Per the Engineers RootBeer MDS 34 12-04-2013 07:58 AM
Explain how MDS operates. DBryant MDS 39 10-09-2013 05:18 PM
MDS engine into non-MDS car issues ehlersa MDS 3 02-02-2012 09:21 PM
MDS a farse? bonehead 2011 Dodge Ram Forum 14 05-18-2011 12:34 PM
CAI + MDS Rasping? jimbodean Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 8 05-20-2010 12:46 PM
