Old 05-14-2011, 04:59 PM
bransonshemi's Avatar
bransonshemi bransonshemi is offline
Vehicle: 2007 RAM
Color: SPARKLY WHITE
Rep:431
bransonshemi is just really nicebransonshemi is just really nicebransonshemi is just really nicebransonshemi is just really nicebransonshemi is just really nice
Default Fab tech question
i have the 6 inch lift from fabtech on my ram, i was thinking about taking it off and going lower, but i asked the people that put it on, LES SCHWAB, and they said once the lift is on there is no taking it off.......sounds like bullS**T to me. what do yall think
Mods: Fab Tech 6 Inch LIFT, Moto Metal SKULLZ, 35''MT's, Spray In Bed Liner, WeatherTech Floor Mats,Paint Match Grille and a REALLY Hungry Motor.
If I CARED ABOUT GAS MILEAGE I WOULD HAVE BOUGHT A KIA
Branson
Old 05-14-2011, 06:31 PM
Not sure why they would say that. Did you ask them why you can't remove it? Seems to me if ya bolted it on, you can unbolt it!
Old 05-14-2011, 07:06 PM
Vehicle: 2007 RAM
Rep:431
they said something about the tranny cross member. im not sure
Branson
Old 05-14-2011, 07:12 PM
So the kit came with a crossmember...big deal. You get a stock one and put that on.
Old 05-14-2011, 07:26 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
All the kits should be complete bolt on...take it off and go low!!!!
Old 05-14-2011, 07:42 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Bolt on, bolt off. Unless they welded it for some reason?
Don't know why you would want to go low though, but hell, everyone has their own thing.
Dillon-aka, The Little Kid
Old 05-14-2011, 10:08 PM
ScatPak07's Avatar
Rep:970
It can be taken off but it is going to cost a lot to do.. Anyway the subframe was cut and the cross member. My shop, which are my buddies, even said that they did not want to take it off because it would be too much of a pain. There is a lot of cutting with these kits. So it is possible but prob be easier not too
Old 05-14-2011, 10:24 PM
Vehicle: 2007 RAM
Rep:431
ahh , ok, i bent my front cross member when i hit a round-about when it was snowing, the lip right under where the two bolts go in got bent, so i need to replace the front cross member, can you buy just the 1 piece or not?
Branson
FYI- Weather Tech Crew cab Rear Vent Visor Install Hemi flash 2011 Dodge Ram Forum 14 08-02-2011 10:34 AM
09+ suspension tech question curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 07-13-2010 11:38 AM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 09:31 PM
Lowering tech question... curt4816 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 11-06-2009 10:39 AM
Question viperfella Dodge Ram General Discussion 7 08-19-2009 02:03 PM
