Old 05-14-2011, 11:38 PM
maxxbnc maxxbnc is offline
Vehicle: 2006 Ram 1500
Trim Level: Lone Star Edition
Color: Inferno Red
maxxbnc is on a distinguished road
Default A/C Question
I just bought a 2006 Ram 1500 a month and a half ago and I am having a problem with the air conditioning. After the truck has sit for a while (say overnight) and I crank it up, the A/C will work fine. If I stop and turn the engine off for 5, 10 or 15 minutes to go in a store for instance, and crank it back up, the A/C will not come on. A couple of times it has taken a minute or two and it started blowing again but then today it never came back on. Any suggestions?
Old 05-15-2011, 07:07 AM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
When you say it takes "a minute or two to start blowing again" do you mean the blower is blowing warm air, or no air is coming out for a minute or two?
Old 05-15-2011, 02:02 PM
Color: Inferno Red
No air comes out at all and I've tried all settings from low to high and from the a/c to the defrost. After a few minutes it will start blowing cold air like normal. It's just delayed for some reason.
Old 05-15-2011, 06:38 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
I'm not an expert by any means but I ask because the blower fan and AC system aren't related, i.e. the AC might be working but the blower might be bad, or the blower could work but the AC could need recharged (it would blow warm air).
Does the blower work on other settings as soon as you turn it on, or does it do the same thing as when you have the AC on?
Old 05-15-2011, 07:22 PM
Rep:2642
almost all of the AC/Heater units are close to the same since about 2002
check out some trouble shooting & repair youtube videos
http://www.youtube.com/results?searc...dodge+ram&aq=f
i especially like the 3 videos from HeaterTreater.net
Old 05-16-2011, 12:43 AM
Color: Inferno Red
The blower does not work at all on any of the settings. But again, this is only after it has ran for a while and then I stop for a few minutes. If it sits for a couple of hours or overnight, the next time I run the engine it functions normally. I don't think the a/c needs a charge cause it blows cold when working. It never blows hot air, just ceases to blow. You may be right about the blower fan going bad. Could it possibly be in the switch?
Old 05-16-2011, 07:35 AM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
Again, I'm no expert but it sounds to me like the blower motor. Maybe somebody with more experience can chime in here...
Pre purchase question: U-Connect iPod Question NumberCruncher Electrical 2 02-01-2011 10:55 PM
Cam Question dodgeguy123 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 01-19-2011 02:05 AM
coolant line question 97ram1500 Heating & Cooling 1 09-28-2010 04:18 PM
Need FAST help!! Noob question!!! kmarshall32 5.9L V8 Specific Topics 8 09-16-2010 12:32 AM
2/4 lowering question jjhwick119 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 11-13-2009 08:31 PM
