Old 05-16-2011, 03:17 PM
Get Bit's Avatar
Get Bit Get Bit is offline
Vehicle: 2004 Dodge Ram RC 4x4
Trim Level: SLT Sport
Rep:71
Get Bit will become famous soon enough
I have been running a procharger HU on my Corvette for 4 years now.. It was making 657 rwhp with 8psi. I have since built a 383 stroker and am going with a D1 procharger and will have around 12-14psi and should make north of 800 RWHP. Granted, it is on an LSx engine and not a hemi, but the concepts of supercharging are all the same.
You also need to think about other things.
Injectors
Fuel supply
Boost-a Pump, or larger fuel pump
Intercooling
Tuning..<-- this is KEY
You can run 3psi and if your tune is not spot on, you can blow an engine. Your timing, A/F, spark tables, knock sensors, O2's have to all be tuned and spot on. The procharger kits are proven and have been out for years.
Check this kit out and call these guys to discuss.
http://www.shophemi.com/p-1137-ho-in...rocharger.aspx
Old 05-16-2011, 04:15 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
exactly what getbit said...do not try to find a "budget" tuner. Not saying that you were, but after all the time and money invested in your motor/truck take it to a good reputable tuner for the peace of mind that when you are screaming at 6000 rpm she's runnin good.
Old 05-17-2011, 04:05 AM
srtsir's Avatar
srtsir srtsir is offline
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Found the guy here locally that can dyno tune it for 300...I already have diablo..But I am pretty sure the prochargers already come with their own diablo tuner with canned tune...
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 05-17-2011, 12:55 PM
Get Bit's Avatar
Rep:71
email diablosport....tell them you already own a predator....see if they have a file for you for a supercharged vehicle with your mods.......and see if they can send it to you. mikel@diablosport.com this will get you going until you can get a custom tune.
FYI diablosport used to do the programs for procharger and a few other companies with global kits.
Old 05-18-2011, 12:47 PM
azzo540 azzo540 is offline
Vehicle: 07 Hemi Ram QCSB 4x4
Trim Level: laramie
Rep:21
azzo540 is on a distinguished road
Send a message via Yahoo to azzo540
Thanx gabrieldy very good info I am going to check out magnuson also...
i am installing the magna charger from magnus on my 07 ram. it is designed for the 09 + rams. it will fit us 03-08 but we need to convert the front of the motor 09 all new kit for the accesories and new alt and wtr pump.
here is the furom that i have on installing it, i am not finished due to this
http://www.ramforumz.com/showthread.php?t=72909
07 1500 QCSB Laramie "Black Betty" Magnuson supercharged, "ATS Diesel" Tranny w/ TCI breakaway TC, Dynatech Super Maxx LT headers, FM Cat-back, K&N
custom doors courtesy of "Axle Break Hill"
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 207 06-07-2013 10:30 AM
Saleen Supercharger for the 5.7L Hemi gregster Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 10-16-2010 04:30 PM
