Old 05-15-2011, 10:17 AM
Corby's Avatar
Corby Corby is offline
Rep:20
Corby is on a distinguished road
Default How to figure gas mileage?
I have a 99 quad cab 5.2L that is sporting 255/75 R16 instead of the stock 225/75 R16. The previous owner who put on these larger tires did nothing about reconfiguring the onboard computer, thus my fuel economy readout is inaccurate and I don't know how to refigure it without popping forty bucks at the dealer for them to reconfigure the computer. Also, is my speedometer still accurate? What about my odometer? What else could this affect?
Old 05-15-2011, 03:18 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Well all the things you mentioned are out of whak with the different size tires. You can go the route of the dealer or go buy a tuner and adjust the tire perameters and then fix other performance items.
Old 05-15-2011, 04:00 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
As far as I know there arent any options to just change the calibration other then go to the dealer or find a tuner with this option.
A tool I like to use to find tire size difference is this:http://www.1010tires.com/tiresizecalculator.asp
It gives you the percentage of what your tire size difference is as a percentage I.E. 10% means when your speedo says 50 your really at 55
Old 05-15-2011, 04:04 PM
Those are a couple of good suggestions!
The speedo and odo are certainly affected. Not sure that much else will be.
Old 05-15-2011, 04:33 PM
JAB JAB is offline
JAB is on a distinguished road
I've got a '97 with a 5.2L. I get @ 12MPG no matter how I drive it (highway, city, different speeds). You can measure distances between filling up w/ a portable GPS unit & keeping a log each time you drive of how many miles. divide total miles by how many gallons you put in. Then compare to readout to see how off it is. There's a throttle body mod on this forum to get 2 more MPG, which I haven't tried yet. I'm pretty sure any air intake/exhaust mods would help also. This probably doesn't answer your question. Just my 2 cents.
Old 05-15-2011, 07:33 PM
Color: Mineral Gray
Rep:177
I forgot to mention that the fuel economy readout is hardly ever correct even with everything calibrated
Old 05-18-2011, 10:19 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
i have the same situation stock tires are 245 i run 265 my speedo is like 3 mph off
-PAT-
Tune Up = Worse Gas Mileage? gain11 5.7L (345 cu in) HEMI V8 Specific Topics 19 01-13-2012 12:13 PM
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 12:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 10:44 PM
Better Mileage tapout007 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 17 04-20-2011 12:41 PM
