Dodge Ram Decals
Old 05-15-2011, 10:53 AM
Bert66 Bert66 is offline
Vehicle: 2011 Ram 1500
Color: mineral grey metalic
Bert66 is on a distinguished road
Default towing capacity
I don't have my truck yet but I'm wondering what my towing capacity would be. I have 20 inch rims 3:55 gear ratio 5.7 hemi crew cab. I'm looking to pull around 5000lbs, can this be done with the current set up?
Old 05-15-2011, 11:20 AM
redlightrico's Avatar
redlightrico redlightrico is offline
Vehicle: 2015 Sport 4X2
Rep:15
redlightrico is on a distinguished road
Yes you'll have no problem with 5000 lbs. If I remember right the standard towing is around 8500 and the max is close to 10,000lbs
The list is soon to be long....much to my wife's dismay
Old 05-15-2011, 11:52 AM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
8750 with the crew cab 5.7 3.55, the only thing I cant remember is the 20inch wheels.for some reason I was thinking that those lowered the rating but cant remember for the life of me.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 05-15-2011, 12:10 PM
BWG56's Avatar
BWG56 BWG56 is offline
Color: Mango Tango
Rep:19
BWG56 is on a distinguished road
10050 with the 3.92 and 8500 with the 3.55
Old 05-15-2011, 12:47 PM
Don't forget to calculate your Gross Vehicle Weight Rating (weight of truck, truck loading, towed item weight) and determine the tongue weight of the towed vehicle.
Old 05-15-2011, 02:12 PM
Thanks guys. I didn't think it would be as high as 8500lbs, I think I saw that 20inch rims would reduce the capacity by 1000lbs compared to the 17's is that right? I wish I knew this before I ordered my truck.
Old 05-15-2011, 02:45 PM
rottekatz rottekatz is offline
Vehicle: 2011 Ram 1500, QC
Color: Cherry Red
rottekatz is on a distinguished road
Here are the Ram spec sheets. Should kill all speculation and dependence upon memory.
http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
So, if you have 20" tires you reduce your max rated trailer towing weight by 50 pounds.
I used this to select my truck.
Help! Towing capacity 2010 Ram 1500. westxsrt10 Towing 21 10-18-2011 12:37 AM
towing capacity??? bluefever Towing 3 02-09-2011 11:06 PM
Towing Capacity barrelracer Towing 1 08-28-2010 01:24 AM
2500 Ram 5.9 Diesel Towing Capacity Captain Ron Towing 3 03-23-2010 12:13 PM
Towing Capacity Joe Rotax Towing 4 06-03-2009 10:10 PM
