Old 05-15-2011, 11:14 AM
geebee's Avatar
geebee geebee is offline
Vehicle: 2001 dodge ram 1500
Color: green
geebee is on a distinguished road
Default lift kit
i am looking for a 2 or 3 inch lift kit where would i be able to find one that is cheaper? also what would be better?
Old 05-15-2011, 01:43 PM
Really, ya just gotta shop around. For the size of a lift you are looking at, a front leveling kit will give you that increase in height pretty easily and cheaply.
Hell Bent makes a leveling kit for your truck.
FabTech & Superlift make some good lift kits if you want to go that way.
What I would do is find what kit fits, then shop on Google to see who sells them to compare some prices. Don't forget to check in with your local shops too!
Good luck!
Old 05-15-2011, 04:06 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Rough country sells a nice 3" lift for your truck for $500 I believe. If your not doing hardcore off-roading, maybe the occasional weekend warrior these are pretty nice kits to go with
Old 05-15-2011, 09:34 PM
geebee's Avatar
Color: green
i got a dodge ram 2500 block for the rear i think its 1 3/4" bigger than my stock ones. what would i need to do for the front? and also will i need to change anything for the steering like the track bar or anything? also will i be able to use 2500 u bolts?
Old 05-16-2011, 04:45 PM
Color: Mineral Gray
Rep:177
You could just get a spacer for the front if you want to go that route or new coil springs. I would recomend getting new shocks. Your stock shocks have enough travel for +2.5" but it doesnt ride as well. I doubt you will be able to use the 2500 U bolts since they have bigger axles
Old 05-16-2011, 07:26 PM
geebee's Avatar
Color: green
so what u bolts do i need?
Old 05-16-2011, 07:44 PM
Color: Mineral Gray
Rep:177
The same size U bolt you have know just longer. Not sure what axle is under your truck but here are some universal one http://www.topguncustomz.com/Store/p....php?S_ID=1065
Old 05-16-2011, 07:52 PM
04limegtx 04limegtx is offline
Vehicle: 2004 Dodge Hemi GTX
Trim Level: Hemi GTX
Color: Lime Green
04limegtx is on a distinguished road
fabtech makes a 3.5" spindle and block kits for your truck for 830 bucks, its a lil pricy, but the most complete kit ive found.
Old 05-26-2011, 10:50 PM
BiggerNasty94 BiggerNasty94 is offline
Vehicle: 1994 Dodge
BiggerNasty94 is on a distinguished road
Hey im new on here. but i have a deathshake on my 94 1500 and have other probs with it to as far as the susp. just needing to help and pointers on it.
Old 06-27-2011, 09:37 PM
projectdodge1500's Avatar
projectdodge1500 projectdodge1500 is offline
Vehicle: 2012 Dodge Ram 1500
Rep:43
projectdodge1500 is on a distinguished road
Default Procomp 3inch lift
I had a Procomp 3inch lift put on my 97 1500 for 1000$, like it and rides pretty good.
2012 Ram 1500 5.7-1993 Dodge Dakota 4.3-2012 Jetta-Crazy Custom Scooters
Trying to get the most height mustang26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-16-2011 06:38 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 10:25 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 11:28 AM
Suspension lift vs body lift usmcoorah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 06-19-2009 12:13 AM
