Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 05-15-2011, 02:43 PM
LILBILL LILBILL is offline
Vehicle: 2005 Dodge Ram
LILBILL is on a distinguished road
Default Plain and Simple
after searching the net, i get mixed answers .will 325 60 20 fit a 4wd on stock 20 rims with a bar crank?
Old 05-15-2011, 02:45 PM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
What is a bar crank? I can run a 305/55/20 on a stock rim with a 1/4 in spacer, otherwise it rubs the control arm. Someone with better knowledge on the 2005 will have to answer that one for you. BTW Welcome to the forums!
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 05-15-2011, 07:52 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I'm going to say no. Your stock wheel isnt wide enough for a 325 tire. You will rub with anything wider then 305 with a stock offset. Its probably to tall of a tire too, with your torsion bars all the way up you might be able to clear a 33" tall tire
Old 05-15-2011, 09:35 PM
i found the answer in a sticky under suspension . wheel and tire guide .
it says 35x12.5
Old 05-16-2011, 04:43 PM
Color: Mineral Gray
Rep:177
it says 35x12.5
With an offset wheel it would fit. Guarantee a 325 will rub on a stock wheel. You will hardly be able to get enough clearance for 35's by just cranking your torsion bars and your truck will handle like crap
Old 05-16-2011, 04:51 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi and a warm Carolina welcome to the best RAM ForumZ on the web. How about using the link in my SIG to jump on the Newbie Checkin for a proper introduction and posting a few photos of your truck?
Old 05-16-2011, 05:16 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Too much tire width for an 8" wide wheel....Not a great or safe idea!
