Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 05-15-2011, 09:00 PM
Troy Troy is offline
Vehicle: 1999 Dodge Ram 1500
Color: Shock Blue with white stripes
Troy is on a distinguished road
Default No Reverse
Okay guys....I have a problem. For some reason my truck won't go into reverse and I dont know why. I just replaced the tranny myself about a month ago and its been working perfectly since then, but today I tried to back out of a parking space and couldnt. I could feel it click into reverse but when i hit the gas it just revved the engine. All the other gears work just fine, except reverse. Do you guys have any ideas?
Old 05-16-2011, 12:13 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I don't have a solution but hopefully one of the techs will jump on the thread and help soon?
Old 12-09-2011, 10:22 AM
slimjim slimjim is offline
Vehicle: 99 4x qc150. 95.250 4x 5.9 gas
Trim Level: sport 150, slt 2500
Color: bl or gy
slimjim is on a distinguished road
MODERATOR? Can we get a BuMp? Or did he? Im looking for some answers to this same problems. TROY a newbie, posted this 6 mos ago in May. I hope we were able to help him & he will return. Mine is on an '01 3.9 w/s with 91k on her. Reverse acts just like neutral. No indication it is attempting to engage into a gear. (reverse) Fluid is at proper level, looks & smells very/suspitiously good.
Old 12-09-2011, 11:16 AM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
If you have no reverse then you are going to have to take the transmission out and rebuild it again, you probably have a direct clutch problem most likely. But just to rule out a few things. Do the fallowing for me and tell me the results.
Put the vehicle in MANUAL 1ST gear and tell me if the vehicle moves when you press the pedal?
If the vehicle moves then it's not a reverse band or low/reverse servo issue.
If the vehicle doesn't move then try checking the band's adjustment and check the low/reverse servo.
Next thing to do is to check that low/reverse servo pressure. The pressure should be around 140-175PSI minimum with a absolute maximum of 280PSI. This check port is located on the passanger side of the transmission closest to the OD Unit.
If everything checks out and you still have no reverse then remove the OD unit and rebuild it again, BE SURE TO TAKE THE OD PISTON SPACER SHIM MEASUREMENT AND THE SPACER FOR THE INTERMEDIATE SHAFT.
If you need help just ask me and I am more then happy to assist.
Old 12-09-2011, 11:20 AM
ramvan2500's Avatar
Rep:128
My reply to Troy is applicable to your issue as well. Just so you know with ATF+4 you cannot judge a fluid change based on the color or the oder. Only with the older fluids are you able to. If you tow change fluid every 12K miles and do a flush at 50K miles, if you don't tow often then change fluid every 50K miles with a flush at 100K miles. Have the valve body rebuilt at 150K to 250K miles in both cases.
reverse, transmission
1999 Dodge Ram 5.2l Automatic Reverse Issue kingme425 5.2L V8 Specific Topics 2 02-05-2011 07:13 PM
No Reverse? The Wook 2011 Dodge Ram Forum 16 02-03-2011 09:35 PM
reverse fuse, or whatever wire i need... oaklandopen 2010 Dodge Ram Forum 1 09-28-2010 06:34 PM
Reverse and Overdrive DYNO Dodge Ram General Discussion 3 06-17-2010 12:02 AM
No reverse in tranny YoMoma 5.9L V8 Specific Topics 16 12-08-2009 10:55 PM
