Old 05-16-2011, 12:51 PM
ekmike ekmike is offline
Vehicle: 1999 ram sport
Rep:20
ekmike is on a distinguished road
Default need some help!!
ok so i have a 318 in my 2001 ram, i find it dosent have any balls like (torque) i can step on it hard on a dirt road and it has a hard time to spin my tires (33" tires on 18" rims) i dont find there that big. My dad had a 2000 ram with a 318 and it had alot more balls. So my question is does it have anything i can do to it to help it out i changed all the fluids in the truck on the weekend, i still have my TB mod that i will be doing tonight or tomorrow night. And i would like to replace the cat with a highflow magnaflow cat and would like to run a CAI or something like that but i'm not sure about the CAI because i like to run my 2wd truck in the woods and mud. So any ideas would help me alot. And the truck has 207 *** miles on her. And for mods that i have to help the power of the truck is i already have a magnaflow muffler and a superchip flashpack at setting performance, and if anybody know's more about superchips let me thanks.
Thanks, Mike
[img]http://i680.photobucket.com/albums/vv169/92_IntegraGSR/Randoms/sigs/Mikesig1.jpg[/img]
Old 05-16-2011, 02:01 PM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
Look down the throttle body and see if there's any oil down there. If there is, a blown plenum gasket is the problem. It lets the intake suck in oil which causes you to lose power, hurts fuel mileage, causes you to lose oil, and it is a common problem on these engines. With over 200K miles on it, I think it's likely the plenum gasket is blown.
This will fix it.
http://www.hughesengines.com/Index/p...3&partid=26190
The stock plenum plate is the problem. It's made of steel whereas the intake manifold it is bolted to is aluminum. This means they will expand and contract at different rates when they heat up and cool down. This makes the gasket blow. The Hughes kit has an aluminum plate that fixes the problem. It's not enough to just replace the gasket.
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
Old 05-16-2011, 03:34 PM
Rep:20
my fuel mileage is good tho and i dont lose any oil when i drive etc..., truck runs fine just wont spin much on the dirt. But i have looked on superchips web site i can change the oil PSI in the tranny it might just do the trick because when i step on the gas it wont rev pass 3500rpm but will red line if i leave it in first so i'm gonna try a few things tonight see if it helps to wake it up some. But ill check tonight around the manifold to see if it has any oil spill.
Thanks for the info
Old 05-17-2011, 11:46 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Hey ekmike, this might sound kind of strange and I might be totally wrong, do you know if your truck has a limited slip differential? It sounds to me like that's what you are describing. I can't get tire spin out of mine because of the limited slip rear end.
Old 05-18-2011, 08:30 AM
Rep:20
i fine that it locks posi in the dirt and when i got it almost stuck in the mud both tires were rousting mud, sometime this week i need to change the oil in my rear end so i check what i have. Ok so i have been playing alitle bit with my superchip and its helping i find, but when i do my TB mod it might help to.
Old 05-18-2011, 09:52 AM
04limegtx 04limegtx is offline
Vehicle: 2004 Dodge Hemi GTX
Trim Level: Hemi GTX
Color: Lime Green
04limegtx is on a distinguished road
Thanks, Mike
imo....i have a 99 with a posi and its still a 3.55 ratio, if you have not done so already, you might want to look at a set of 3.92 or 4.10 to help you spin tires, exspecially if you take it in the wods and whatnot, also my truck has the 5.2 as well and it was being sluggish and we took it to the local dealer and they put a new timing chain and gearset in, and WOW it made a huge difference, just my $.02
Old 05-18-2011, 10:00 AM
Rep:20
ya i have 3.55 gears, i was thinking to change the gears i figure it would help the truck. Do you know where i could buy a set of 3.95 or 4.10 gears?
Old 05-19-2011, 08:15 PM
coonhound130 coonhound130 is offline
coonhound130 is on a distinguished road
gears can be bought at any parts store or Jegs, summit and so on . Cheap mod but will also kill your gas mileage if you go too much
Old 05-19-2011, 11:57 PM
toddrod's Avatar
Color: Yellow
Rep:55
Before you change the fluid in the rear end, find out if you have a limited slip differential. If you have one, you need to use a friction modifier additive to your oil. Chilton's manual says it only needs 5oz. if I remember correctly. If you don't use the modifier you'll get a nasty chattering in the rear end.
Old 05-20-2011, 12:32 AM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
i have an 01 5.2 same set up only i have 31 inch tires. sounds crazy but see if you have slack in your gas pedal . mine had like two inches of slack i pulled the slack out and zip tied the cable under the pedal. it made a world of difference more throttle response and i hear my cai sucking air. give it a shot cant beat the price of a zip tie. i was blowed away at the difference it made good luck!
-PAT-
