Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 05-17-2011, 12:44 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
I dont see much of a cost savings, if 1 tank of 87 cost 60.00 and 2 tanks of E85 cost 90.00+ to go the same distance. The E85 will burn cleaner and be better for the world we live in, but E85 lacks the "punch" gas has, thats why the mileage is so poor. Even the added 10% ethanol in our regular gas has caused a drop in mpg. I lost roughly 15-20 miles to a tank of gas in my Dakota when they added 10%. Thats why I had a post going about using R90 "recreational 90" gas its used in boats, chainsaws, etc.. engines that were not desinged to run on gas with ethanol added to it, its 90 octane and the 5.7 likes 89. But its "not" for daily driver use because its not taxed like regular gas.
So try it and see how it goes the 4.7 is a flex fuel engine. Like mentioned above I wouldnt use it if I had a load on the truck like a camper and four wheeler. I would try it around town first.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 05-17-2011, 06:15 PM
RockyRam's Avatar
RockyRam RockyRam is offline
Vehicle: 2016 Ram
Color: Blue Streak
Rep:851
RockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to behold
Originally Posted by ArmyofOne View Post
all th 4.7's were flex fuel from 08-present.
It started in 07.
Yeah the ethanol runs 30% more. A good way to think of it is, multiply the cost of ethanol by 30%. if it comes out lower than the difference is from reg gas, it is worth your $.
Old Ram -->
Have a Gray Ram?? Join the Mineral Gray Metallic Ramz Group!!!
http://www.ramforumz.com/group.php?groupid=21
Old 05-21-2011, 01:08 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1217
my bad you are right. 07+. And Every time I have used E85, I have noticed a power INCREASE. Maybe just me but it seems like it had more power than on regular 87 octane.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. 60k Miles. 5100's @2.8 Adj Coilover front struts. 3" Lift done my way. BF-Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, spray-in Liner, Mud Flaps, 20% tint, SS Side Steps, TruXedo Roll-up Soft Tonneau, SS Bull Bar, 10k Lumen 22" Solidex LED Bar, DZ Tailgate assist, TLC, AVS Visors and Bug Shield, K&N, XenonDepot 5000k HID Headlamps in projectors.
Old 05-21-2011, 01:49 PM
JayBones's Avatar
JayBones JayBones is offline
Vehicle: 2008 Ram 1500 4.7L Standard
Trim Level: TRX4 OFF ROAD
Rep:55
JayBones will become famous soon enough
I'd be careful with that statement. Right in my manual it states that SOME 4.7's come with the OPTION of flex fuel.
My '08 does not have the option. Maybe in the States they all do, I don't know about that, but there are many 4.7 owners on the forum who would also NOT have the flex fuel option.
Bullydog GT GAS tuner, Diablosport Intune ordered, AVS vent visors, Line X under rail bed liner. BFG All Terrain T/A KO tires. Symbolic aluminum grille insert. K&N drop in filter
Old 05-22-2011, 01:12 AM
ArmyofOne's Avatar
US Army Retired
Rep:1217
May have been an option in canada, but in the USA to my knowledge, they are all FFV's
Best way to tell is look for the yellow gas cap. If you dont have it, dont use it.
Old 05-24-2011, 01:55 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
2010 Ram 1500 4.7L 4WD Ratings
Gasoline = 13/18 15 (Disclaimer: EPA Test on G100 not the typical E10 Blend)
E85 = 9/12 10
Gene
Old 05-24-2011, 04:49 AM
southpaw5m's Avatar
southpaw5m southpaw5m is offline
Vehicle: 2003 dodge ram 4.7L
Color: Patriot Blue Pearl
Rep:23
southpaw5m is on a distinguished road
If it's all about the fuel economy, then get a tuner that allows you to adjust your air/fuel ratio. Gas is 14.7.1 and E85 is 9.67.1...That's why mileage and performance may be crap. Don't hate E85 just because the engine isn't tuned right.
Old 05-25-2011, 09:06 PM
Its not the tuning. The tuning is already right in a Flexfuel vehicle. Using the stoich numbers you gave (actually peak fuel mileage occurs at a leaner ratio than this at low cylinder density) by your own numbers it requires 1.52 lb of alcohol for every lb of gasoline to make equivalent power. Given that gasoline typically weighs 6.073 lb per gallon and ethanol 6.584 lb per gallon you will use approximately 40% more alcohol (in gallons) than gasoline. Thats a 29% drop in fuel mileage. im not going to try to convert from pump gas to E85 because the actual percentage of ethanol in pump gas can vary form 0-15%.
Gene
Old 06-07-2011, 09:46 AM
GolfSIX GolfSIX is offline
Vehicle: 2010 Ram 1500 QC
Rep:25
GolfSIX is on a distinguished road
Anyone know where is Washington State you can buy E85, I can't find it anywhere is BC
Si Vis Pacem...
Old 06-07-2011, 12:00 PM
ArmyofOne's Avatar
US Army Retired
Rep:1217
There is not currently a gas pump in this state (public anyway) that pumps E85.
