Old 05-16-2011, 06:37 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Question Pinstripe removal???
Just wanted some opinions on my truck. It has a black pinstripe from the front all the way to the back and was contemplating immediate removal!!!! I have a spot on the bed that is starting to come up...so it should be pretty easy!!!
Yes or No???
Old 05-16-2011, 06:43 PM
JoshuaCor JoshuaCor is offline
Vehicle: 2003 dodge ram 1500
JoshuaCor is on a distinguished road
should be easy i did this for my truck and it looks amazing now
if you dont already know how to go about removing the pinstripe follow these instructions
1. get a hair dryer
2. heat up small portions of the pinstripe
3. use a plastic scraper and scrape it off.
if you have stubborn old pinstripes like i did.
you can get a dish sponge with a scrubber side and get a bowl of warm soapy water and scrub the stripe off. and after its all scrubbed off there will be scuffs in the clear coat of the paint and you can get some compound and buff that out.
Old 05-16-2011, 07:19 PM
RockyRam's Avatar
RockyRam RockyRam is offline
Vehicle: 2014 Ram
Color: True Blue
Rep:851
RockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to beholdRockyRam is a splendid one to behold
Send a message via AIM to RockyRam
Yeah it'll come up easily. Don't forget pictures when you're done!
Have a Gray Ram?? Join the Mineral Gray Metallic Ramz Group!!!
http://www.ramforumz.com/group.php?groupid=21
Old 05-16-2011, 08:49 PM
Lmood Lmood is offline
Vehicle: 05 ram slt
Color: silver
Rep:258
Lmood is a jewel in the roughLmood is a jewel in the roughLmood is a jewel in the rough
3m makes a product called a pin stripe remover or a sticker eraser. its bassically a big round eraser that you can put into a drill or air tool. you can cut the time of removing the stripe by about 3/4. if you go this route. make sure you KEEP THE DRILL MOVING! if you hold the drill in one spot for too long youll burn the paint. good luck!
LOOK PARIS......SOMETHING BLUE!
Old 05-17-2011, 01:10 AM
rinnels69's Avatar
rinnels69 rinnels69 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:19
rinnels69 is on a distinguished road
TRUE ^^^ The pinstripe removal wheel also works on any other sticky items....dealership logos/advertisement, residue from de-badging, etc. I have NEVER liked pin stripping from the dealer...it RARELY looks good, and they charge $100 for $10 pinstripes and 30 minutes (or less) time. A total rip-off if ya ask me. Luckily, mine didn't have any . Thank You Patterson Dodge!
MODS: G2, Timbren SES, ITBC, de-badged....to-do--HB horns and nerf bars
Old 05-17-2011, 01:16 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Yeah heat it up a bit, and use the wheel after. Careful when using the wheel to not burn (eat up) the paint clear coat.
Door panel /Window/Mirror removal on 2010 rtkman Dodge Ram Knowledge Base 20 09-16-2015 02:07 AM
Front Bumper Fascia,Grill, & Bumper Removal Write Up moparornocar72 Dodge Ram Knowledge Base 11 09-21-2014 10:40 AM
DS Body Instrument Cluster Removal RamTech Dodge Ram Knowledge Base 3 11-23-2010 01:44 PM
Factory fog light removal ram4x4 2009 Dodge Ram Forum 9 06-05-2010 09:53 PM
Dash removal. Dieselkiss Body & Interior 0 03-11-2010 09:57 AM
