will new exhaust help a lot with power and mpg? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Old 05-17-2011, 12:55 AM
bigblack21 bigblack21 is offline
Vehicle: 1999 Dodge Ram
Rep:46
bigblack21 is on a distinguished road
Default will new exhaust help a lot with power and mpg?
ok so plan on putting a true dual exhaust with not cats on my truck this summer. i am planning on getting long headers and going with a 2.5 or 3 inch pipe. i am also going to put some mufflers with tips to get a little better sound. but will this help with mpg's and power or just power? my truck is getting about 11 mpg which is terrible so i want to do something that will help and also give me more power. i also plan on buying a new air intake too. how much will that help also?
Old 05-17-2011, 01:25 AM
JoshuaCor JoshuaCor is offline
Vehicle: 2003 dodge ram 1500
JoshuaCor is on a distinguished road
intake will increase your HP and your MPG
and exhaust will help to an extent.
it wont be to noticeable but there will be a small gain ( if you can keep your foot out of it)
Old 05-17-2011, 01:46 AM
1loudmouthpony's Avatar
1loudmouthpony 1loudmouthpony is offline
Vehicle: 1995 dodge ram 1500
Trim Level: laramie
Color: Green/Sliver
Rep:14
1loudmouthpony is on a distinguished road
both the intake and running a better flowing exhaust will help in power and mpg, but not a whole lot. however i would probably either keep your cats, or upgrade to a higherflowing one, incase of emmissions and inspections.
Old 05-17-2011, 04:57 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Those two combined will cause an increase in power, but i'm not certain it will help mpg's. I don't want to sound like a dick, but if you bought a truck, you shouldn't have been worried about gas mileage. Especially with a 5.9. These motors are terrible on gas and there's really not a whole lot out there to improve it. Mine's averaging about 12.3 with mostly city driving.
As for the exhaust, I wouldn't recommend running no cats. Sure, you can get special things to clear any codes that the O2 sensors will throw, but it still will screw up the air/fuel ratio and won't help your mpg's at all. You'd be better off going with some better flowing cats rather than no cats at all. And I wouldn't run 3" pipe either. These motors have to have some back pressure or you'll lose low end torque. The biggest pipe I'd recommend would be 2.5" at the most. You can run 2.25" and be just fine.
Old 05-17-2011, 07:45 AM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
JCasey10 is right on the money...... Only thing I will add is to check the TB to see if cleaned and check the plenum to see if it's leaking. Both can cause lost of mgp.
Old 05-17-2011, 08:32 AM
bigjeff64's Avatar
bigjeff64 bigjeff64 is offline
Vehicle: 2001 Dodge Ram Quad Cab
Rep:20
bigjeff64 is on a distinguished road
it will help performance thats for sure but ull be driving under every overpass and kickin it in neutral just to rev it and listen to the beast roar!!!!!
i average 12.9 mpg between city and highway u can change ur rear end gears to run a lower ratio but that can be pricey. the show xtreme 4x4 took a ram 1500 5.9 4x4 and did an episode on things to do specifically to help with mpg's it was pretty informative.
Old 05-17-2011, 11:30 AM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
An exhaust by itself probably won't give you much. Now, combine a better intake to an exhaust and you'll most likely start noticing an improvement. I would do these
Throttle body mod-- http://www.ramforumz.com/showthread.php?t=46431
Intake manifold mod-- http://www.ramforumz.com/showthread.php?t=80192
Both of these mods are free and will let you take advantage of the free flowing exhaust system you put on. I think if you do true duals with headers like you planned, open up the throttle body and intake manifold, and put on a cold air intake, you'll feel a much more significant difference than if you did just the exhaust alone. The best part is that you won't even have to spend any more money than you would have. Plus, it gives you a good base for future mods like a cam, rockers, tuner, etc.
I would also agree with those who said to keep the cats. The difference you feel would probably be negligible and having them on could save you a ton of headaches when it's inspection time.
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
MPG mods TSuppa 5.9L V8 Specific Topics 7 06-24-2015 02:48 PM
new mpg high - 21.2! CHVYKLR 2009 Dodge Ram Forum 15 06-22-2011 12:32 PM
Another way to get more power? New95Ram 5.2L V8 Specific Topics 19 02-25-2011 03:45 PM
less MPG? jordanj273 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 15 11-25-2010 10:08 PM
Any real world results? (MPG gain with tuner?) HoustonHemi Dodge Ram MPG Zone 12 06-05-2010 12:00 AM
