Old 07-03-2014, 03:40 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:156
topsub has a spectacular aura abouttopsub has a spectacular aura about
Originally Posted by PJRNM View Post
I think it depends on the head unit. The stock camera has wires that run to the power distribution center as well as to the back of the head unit. If the aftermarket unit uses the stock connectors, it will probably work.
Using this head unit Alpine INE-W957HD with pac rp4 ch11 modual
2016 F250 Lariet FX4 CrewCab 6.7L
2012 Dodge Laramie 4x4 CrewCab Supercharged and Lifted - SOLD
My Build Progress
Old 07-03-2014, 06:20 PM
PJRNM's Avatar
PJRNM PJRNM is offline
Vehicle: 2012 Ram 1500
Trim Level: SLT Bighorn
Color: True Blue
Rep:17
PJRNM is on a distinguished road
Topsub,
I'm not familiar with that head unit, maybe someone here will be, and will be kind enough to chime in.
Old 07-08-2014, 08:32 PM
Color: Blue
Rep:156
Do we know if the factory rear camera uses a video signal or is it some mopar trickery?
I also have a spray in bedliner, Is that going to limit me on accessing the tailgate handle?
My Build Progress
Old 07-08-2014, 09:21 PM
PJRNM's Avatar
Color: True Blue
Rep:17
I think it is just a video signal, but I'm not sure. The bedliner won't be a problem, I have LineX. The stock camera includes a new handle, with the camera built in.
Old 07-08-2014, 09:27 PM
Color: Blue
Rep:156
When I pulled my factory head unit I didn't see a video signal wire.
Wonder if there is module or I will have to buy another reverse camera
My Build Progress
Old 07-09-2014, 09:10 PM
PJRNM's Avatar
Color: True Blue
Rep:17
Here's a picture and text from the installation instructions. Not exactly crystal clear, but it may offer some guidance figuring out which wire(s) are the video feed.
52. Remove the white C3 connector from Radio (If Equipped). Some vehicles may have cavities 3,4, and 5, of the C3
connector populated remove existing terminals and proceed to next step.
53. Lift C3 terminal locking Tab, Insert Terminal as shown above. GY/LB into Cavity 3, GY/OR into cavity 4, Uninsulated
shield wire into Cavity 5. Relocate terminal locking tab. If Vehicle is not equipped with white C3 connector Populate
Connector supplied in kit.
Old 07-09-2014, 11:01 PM
Color: Blue
Rep:156
I'm wonder if the wiring harness for the stock camera has an ACC power and ground i can use for my aftermarket camera.
Seems there isn't a way to use factory camera with aftermarket headunit.
My Build Progress
backup camera
Factory Backup Camera RBZ Lockpick hockeyman2000 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 05-10-2011 09:56 AM
Aftermarket Backup Sensors space85 2011 Dodge Ram Forum 2 01-25-2011 01:27 PM
Aftermarket Backup Sensors Help Please space85 Electrical 6 01-24-2011 10:26 PM
2010 ST Factory RKE or Aftermarket Security System phillymac23 2010 Dodge Ram Forum 2 08-10-2010 11:59 AM
Factory alarm and aftermarket alarm sys rosie3 Electrical 3 12-30-2009 10:40 AM
