Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 05-17-2011, 10:58 PM
tcarlton0516 tcarlton0516 is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x4
Color: Blue Streak
tcarlton0516 is on a distinguished road
Unhappy Leaking oil filter?
The dealership did the first oil change for free. No problems, no leaks. I've done oil changes on vehicles for almost 30 years. Never had one leak. I did the second oil change on my truck (5.7 Hemi) Used a Mobil One M1-210 oil filter. It leaks, I've hand tightened it several times. It starts to leak again a few days or a week later? What gives? Can I take the filter off and put a new one on without losing a bunch of oil? I've never taken off an oil filter off without first draining the oil pan. Did I use the right filter? Any help will be appreciated.
Old 05-17-2011, 11:24 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The oil is going to come out pretty good! You might be able to slow the flow by leaving the oil fill cap on!
Old 05-17-2011, 11:25 PM
emmyshemi's Avatar
emmyshemi emmyshemi is offline
Vehicle: 2017 Ram 1500 crew 4x4,
Color: Max Steel
emmyshemi is on a distinguished road
I might be wrong..but I think there are 2 diffrent sized oil filters for the truck. That might be it, but I don't think the wrong one would have screwed on. As far changing the filter, you are going to lose some oil, but most of it will remain in the pan on a cool engine. You will just have to top it off after you change the filter. Good luck.
How about I put my "carbon footprint" up your liberal ass?
Old 05-18-2011, 08:55 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:33
charlieb is on a distinguished road
oil is cheap you need to drain or you will make a mess.you can drain into clean containerand re-use not a big deal.your gasget must be defective.did you try using a filter wrench and tighten a little more? wont be a big deal getting off if u conditioned the seal b4 you installed it.there is no reason a filter would back off by itself if its tightened properly the gasget friction would not allow it.
Old 05-18-2011, 09:09 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
is the old gasket from the filter you removed still stuck to the block? usually only happens on the first oil change b/c the factory installs the filters really tight but it could be double gasketed.
I've only seen it once but a friends truck had a pinhole sized hole in the filter causing a really really small leak. only way we could figure it out was to roll underneath with the truck running, wipe the filter down and look for the accumulation.
Old 05-18-2011, 09:16 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
gabrieldy beat me to the punch line. An excellent thing to check for. Doesn't happen often, and can catch the best of us.
Taking off the oil filter will not make much more of a mess with the engine oil in place. As stated above, you will have to top up after doing this, which will likely be 1 qt or less. If you do find a second unwelcome gasket, you can remove it an put the same filter back on....or a new filter in the case of no extra gasket.
brad
Interested in one of my mods?
Old 05-18-2011, 01:14 PM
Color: Blue Streak
Thanks for all the ideas. I don't think it's a double seal. This is the third filter on the truck, 1st filter was from the factory, the 2nd was from the dealership. Only this third filter has leaked. I don't think it's a pinhole in the filter since I had to tighten the filter by hand a couple of times. It seems to be working loose? At this point I think I'll try to get as tight as I can by hand then put a filter wrench on it and snug it down just another quarter of an inch. That should be plenty tight. If it works off again I'll just remove it and put a new one on. At that time I can look for a double seal or any remnants of the original seal. Any idea if I am using the right Mobil One filter? M1-210 is what I have on there.
Old 05-18-2011, 03:56 PM
Rep:2890
i would almost bet that the old gasket is still in there
i personally use the WIX oil filter part #57899
Oil Filter 57899 V8 5.7L 345 CID HEMI D,T PICKUP RAM SERIES - ALL Engine Code EZD
if the oil filter hangs straight down on your Ram, fill it 1/2 full of oil before putting it on, make sure to lightly oil the gasket
Old 05-18-2011, 04:57 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PXR Black
Rep:2477
Smile
Here are a couple of pics that may help, the first pic shows the old and new filters, the one on the right was the factory filter. Notice the 22 M stamped on it. That's the metic thread size. They switched them from imperial not that long ago and the old one may thread however would be loose. This may be your problem. The other pic is the filter and oil that I used, the filter is the same one that GTYankee mentioned however from UAP NAPA (It is a WIX as well).
sales@revelperformance.com
Old 05-18-2011, 05:21 PM
wannab's Avatar
wannab wannab is offline
Vehicle: 2011 Hemi sport
Trim Level: Sport QC.
wannab is on a distinguished road
I changed my oil at 400 miles, and the gasket stuck on the block from the factory filter and I had a leak. Pulled off filter removed one of the gaskets and the leak stopped. You have to at least pull the filter and check for double gaskets. I have never had a bad filter and have been changing oil for 30 years. man I am getting old.
2011 Black Sport Quad cab Ram, Magnaflow midpipe back exhaust, K+N intake.
Which oil filter is best?? Mr.Clean 5.7L V8 Specific Topics 21 03-24-2012 01:20 AM
leaking oil from front axle roundtownram Dodge Ram 4x4 - Offroad Discussion 2 04-29-2011 05:04 AM
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 07:23 PM
Mopar oil filter leaking? bighorn10 2010 Dodge Ram Forum 14 11-07-2010 09:40 PM
