Old 05-17-2011, 11:49 PM
Frankenstein Frankenstein is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: SL
Color: Teal
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
Frankenstein is on a distinguished road
Default 96 stock 2500 question
I have a stock 1996 2500. Ive searched n everything im seeing is mixing me up. Id like to fit 35" under it but unsure of what size lift it needs. Anything helps
Old 05-18-2011, 10:15 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
You should be able to clear 35's with stock suspension actually. I did with an 05 2500. I would recomend getting a hell bent steel leveling spacer as a just in case. If you have stock wheels you will have rubbing on the control arms at full lock with 35x12.5
Old 05-18-2011, 12:42 PM
Trim Level: SL
Color: Teal
What could i do to keep from rubbin at full lock? Spacer or aftermarket wheels? What backspacing?
Old 05-18-2011, 03:43 PM
Color: Mineral Gray
Rep:177
To keep if from rubbing on the control arms you need an a negative offset or around a 5.5" backspace I think (stock is 6") When you push the wheels out the you'll cause rubbing on the lower fenders which is fixed by the leveling kit.
You can go the spacer route but I can tell you that 1/4" is not enough. I tried 1/4" and 1/2" and still had rubbing and ended up with a set of 1.75" wheel adapters. You have to be really careful when using wheel adapters/spacers. Aftermarket wheels are a lot safer choice
Old 05-18-2011, 03:44 PM
Color: Mineral Gray
Rep:177
The rubbing on mine was only about the size of a quarter on the lower control arms. It wasnt a big deal but with a quad cab long bed I needed full turning radius
Old 05-18-2011, 09:52 PM
Trim Level: SL
Color: Teal
Maybe a stupid question that i prolly know the answer too but will 35s fit on stock rims?
Old 05-18-2011, 10:13 PM
What they said is good advice.
The stock rims on your truck are how wide? 8.5"? It's not the diameter of the tire that makes a difference, it's the section width.
265 = OK
275 = OK
285 = OK
295 = OK
305 = OK
315 = OK
325 = NO
35 X 12.50 = marginal.
Old 05-18-2011, 10:19 PM
Trim Level: SL
Color: Teal
Lookin at 315/75-16, ok?
Old 05-18-2011, 10:29 PM
What mfgr tire are you going with?
Those will fit. Minimum rim width for that section width tire is 8"
Old 05-19-2011, 09:00 AM
Trim Level: SL
Color: Teal
I thought the stock 1996 2500 wheels were 6.5" width?
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Vibration around 2500 rpms lucidanomaly Newbie Checkin! 14 04-25-2012 01:15 AM
1998 Ram 2500 4x4 Stock Height??? Quiet Lunatic Dodge Ram 4x4 - Offroad Discussion 1 04-28-2011 11:42 PM
Stock Wheels Question CraigsRam Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 04-21-2011 12:13 PM
2500 5.9 gas lacking towing power question Nick B Towing 1 04-09-2011 02:23 PM
