Airbag light w/ no code....Confuse - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 06-01-2011, 07:37 AM
SpecialEd's Avatar
SpecialEd SpecialEd is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
SpecialEd is on a distinguished road
Hmm, I selected the passenger airbag to off and the off light did not light up. Hopefully, replacing the bulb will cure the light.
Thanks Brad
Old 06-01-2011, 09:33 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Let us know how you make out. This could turn out to be one of those little things that helps out a lot of members.
brad
Interested in one of my mods?
Old 06-01-2011, 10:12 PM
SpecialEd's Avatar
Color: Blue
I removed the passenger airbag swith to change bulb but there was no bulb to be found. Any suggestions?
Old 06-06-2011, 03:05 PM
SpecialEd's Avatar
Color: Blue
Anymore recommendations/suggestions before I give in to the Dealer? What else could cause the circuit to stay open even after the system has been reset by the proper scanner?
Old 06-06-2011, 03:21 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Originally Posted by SpecialEd View Post
This airbag light on the instrument cluster is really annoying. I have checked everything, scanned the sytem using the proper scan tool and got no codes but the scan tool does recognize the light as an Open Warning Lamp. Q: What else that would cause the night not to go our even after the system has been reset?
On many cars recently they made it so the light for the air bag goes on at a normal schedule. The reason why is really so you take it to a dealer so they can get money out of you but they claim it's cause they do regular tests on the system to make sure everything is in order so that light doesn't only mean there may be a failure but it could just mean that it's time to get it checked. My mother hyundai is like that, the light goes on because it's suppose to get hooked up to the dealers tool to do a test. I know it sounds odd but sometimes the simple things you can find the answer in the owners manual! LOL
Old 06-06-2011, 04:08 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Smile
LOL - Then if your under the truck running wires and accidentally roll on your remote start button twice, the truck doesn't start and cause you leave a heavy brown streak across the shop floor.
Not that this has happened to anyone I know while installing an electric tailgate lock.
Now that's some funny stuff right there
sales@revelperformance.com
Old 06-07-2011, 07:39 AM
SpecialEd's Avatar
Color: Blue
My uncle ownes a mechanic shop and he has the proper scanner tool to scan and reset the system (airbag). He doesn't know much system other then what the scan tool indicates. On the initial scan, the scan tool detected and displayed a code for the airbag, reset system and code went away but the airbag light on instrument cluster remained on (passenger airbag disable warning lamp open.
Old 06-07-2011, 09:09 AM
brad12kx's Avatar
Rep:2581
There should be a cover for that assembly with the lamp in it.
Do you have pix of all the pieces?
brad
Old 06-07-2011, 01:02 PM
SpecialEd's Avatar
Color: Blue
Brad,
The cover is attached to the panel. There are 3 srcews attaching switch to the (cover) panel. I will remove the panel again and search the inside for the missing lamp etc..
Thanks
Old 06-13-2011, 02:11 PM
SpecialEd's Avatar
Color: Blue
Well, I removed the switch again and there wasn't a bulb anywhere to be found. Not exactly sure of the type of bulb to install since there wasn't one there. The dealer wants $35 plus tax for another switch and he did not sound to convincing to whether or not a bulb should be installed.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 20 12-13-2017 06:32 AM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Airbag Light **** Confused!!! SpecialEd 3.7L PowerTech V6 Specific Topics 1 05-18-2011 06:01 PM
airbag light problem airmounce23 Electrical 1 04-14-2011 06:15 PM
