Old 06-29-2011, 08:59 PM
ramoreno's Avatar
ramoreno ramoreno is offline
Vehicle: 2002 Dodge Ram
ramoreno is on a distinguished road
i have the same problem. and i read in othr forum, or i dont remember, is the switch, because when you disconect the switch and put the wire back and is in off position the charge of electricity is more and you burn out the switch, if you put it back in on position nothing happen, something of the amps. i dont know, that happen to me. and i remember see in a mechanical manual too. tell me if fix with the new switch, because im gona need one too. sorry for my english.
Old 07-15-2011, 08:52 PM
SpecialEd's Avatar
SpecialEd SpecialEd is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
SpecialEd is on a distinguished road
Ramoreno,
I purchase a switch from the dealer, since its a dealer only part ($37.50). I disconnected the negative battery cable, installed new airbag switch, reconnected battery and the airbag light is out!!!! The switch was the problem. You was connect concerning the voltage overload when reconnecting the connector plug. Anywho, the new switch solved my contious airbag cluster light on for me. Hopefully, if others are experiencing the same problem, the issue might be the switch also.
Old 07-21-2011, 09:48 PM
ramoreno's Avatar
Originally Posted by SpecialEd View Post
Ramoreno,
im glad you finally fix the light, thanks for let me know, im gona do that for my truck. but is more expensive in here. so im gona wait a little, because i need my clockspring too, spill out some beer on it. thanks again and sorry for my english
Old 03-08-2012, 12:28 AM
sgreuel sgreuel is offline
sgreuel is on a distinguished road
I had this same problem of the airbag light staying on after having the entire dash removed from a customer's 2002 Ram 1500. The truck showed no DTC's. After reading this post i decided to check this same switch. When I checked it, I had simply left that switch unplugged. Thank you all for your posts which helped me diagnose this problem.
Old 04-07-2012, 08:43 PM
KwS-Blackout's Avatar
KwS-Blackout KwS-Blackout is offline
Vehicle: 2005 Ram 1500 Daytona
Trim Level: Daytona
Color: Go Mango
KwS-Blackout is on a distinguished road
Do you have a part number for that switch? My 05 Daytona has the same problem after the previous owner put an aftermarket head unit in the truck. The light does not display off when switched over.
Old 04-08-2012, 06:31 PM
Trim Level: Daytona
Color: Go Mango
Hey guys, I just posted a tutorial with detailed pictures and instructions on how to fix this issue. You can visit the post here. I hope it helps and isn't to crappy lol. Let me know what you all think.
Old 04-15-2012, 09:13 AM
Zipn Zipn is offline
Vehicle: 2002 dodgevram1500 4wd
Trim Level: Base
Zipn is on a distinguished road
Hello all
New here. This is my first post, found this forum after searching the web or the airbag light issue. Just wanted to say thanks! Had the same problem. I noticed the airbag off light at the switch was not coming on when the switch was off, causing the dash light to come on. I took the switch off and pulled it apart on the bench to clean it. Better now though I think for the low price of a new switch I'll jut get new one.
Fow what it's worth, the bulb was fine it is just that the sw was dirty. Don't really see how a power surge could damage it as there isn't much to it... I suspect it is just dirt and oxidation from never being used and the removal from the Dan causes the problem.
Thanks again
Old 05-04-2012, 09:28 AM
jrodrg jrodrg is offline
Vehicle: 06 Ram 1500 SLT, 06 Mitsu EVO
Color: Grey
jrodrg is on a distinguished road
My Airbag light just came on too, not head unit related (OE radio). Thinking of checking the fuse first then the bulb. Where is this switch located? Is it a pain to get too? I have an 06 ram 1500 slt
Old 07-14-2013, 02:32 PM
aston4 aston4 is offline
Vehicle: 2003 ram 1500 worktrk 4.7/4A
aston4 is on a distinguished road
same thing happened to me, i was messing with the stereo & the light popped on (the car was running so i could have the a/c on because it is HOT). thanks to you all i tracked down the problem to the bulb. since it's sunday i just ran by radio shack and picked up a "mini lamp 12v 25ma" and soldered it right over the top - didn't even remove the old bulb. total time to fix after obtaining the bulb less than 10min. hopefully it will last a while i've used these same bulbs before for vintage radio repair and they sometimes blow in two hours and sometimes last for decades. the part number is 272-1141 in the radio shack catalog if anyone need a fast fix.
Old 11-30-2013, 12:51 PM
Gary 2's Avatar
Gary 2 Gary 2 is offline
Vehicle: 07 Ram rc sb
Trim Level: SLT Sport
Gary 2 is on a distinguished road
The mini lamp trick just worked for me also. Dealer had no switch in stock and said he would order one for me so I figured what do I have to lose .The new switch would be free anyway. That's free if the dealer ever remembers saying he would mail it to me . For $1.99 I bought two . worked perfect the red Airbag light on the instrument cluster went out . Thanks for the tip
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Airbag Light **** Confused!!! SpecialEd 3.7L PowerTech V6 Specific Topics 1 05-18-2011 07:01 PM
airbag light problem airmounce23 Electrical 1 04-14-2011 07:15 PM
