Old 05-23-2011, 07:13 PM
rinkman's Avatar
rinkman rinkman is offline
Vehicle: 2011 dodge ram 1500
Trim Level: big horn
Rep:89
rinkman will become famous soon enough
Originally Posted by BigHorn 4 Life View Post
That is why you should get the bilsteins because they are adjustable from stock setting,1.4",2.1",and a 2.8"= mine. So if you go with the 5100's and you raise your front end with them. Later on put a 4" lift on then lower your setting of your bilsteins to 1.4" or stock setting. So ya a would do the bilstein 5100's.
Verses getting the leveling kit that has spacers you would never use when putting on a 4" lift. Bilsteins are a win win to me. Just trying to help ya out bro.
I agree with BigHorn, go Bilstein's. If I was starting from scratch I would definitely go Bilstein's.
Old 05-23-2011, 07:59 PM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
Sweet deal guys. Definatly makes sense to get the bilsteins since I want to add a 4in later down the road.
How do the 3.55 gears hold up to a set of 35in tires on 20in rims?
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
Old 05-24-2011, 12:27 AM
linksus89 linksus89 is offline
Vehicle: 2008 Dodge Ram TRX4
Rep:12
linksus89 is on a distinguished road
I just did a 6 inch lift and put 35" tires on my rig which has a 3.55 gear ratio. Ive noticed a bit of a loss in the get up and go off the line but im not one for having a heavy foot anyway so that does not bother me much. You should be fine with the 3.55
Old 05-24-2011, 09:56 AM
Greg50Lt's Avatar
Trim Level: Sprot
Rep:20
sweet deal. Thanks for the input
Old 05-24-2011, 02:08 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
I ahve 37' tires with 3.55 gears. It does great!! I am going bigger on my next set so I might do some type of gear upgrade before I get wider tires.
As linksus89 said you will be fine.
Old 05-25-2011, 12:56 PM
Greg50Lt's Avatar
Trim Level: Sprot
Rep:20
after doing some research about the bilsteins I found this tell me what you think
http://www.topguncustomz.com/Store/G...view=257740083
Old 05-26-2011, 03:22 AM
dauer53's Avatar
dauer53 dauer53 is offline
Vehicle: 2011 1500 Quad Cab Sport 4x4
dauer53 is on a distinguished road
I just ordered them from shockwarehouse.com for $369.99 & free shipping, down side is they are backordered until (I'm told) the end of the month... topgun has them marked up way high because they have some right now... I called a couple different places & they were all backordered too... I figured another couple of weeks was worth the extra almost $300 savings.
Old 05-26-2011, 05:20 AM
Rep:463
Sweet sounds like a really good deal. We want pics or it never happend .
Old 05-26-2011, 09:54 AM
Greg50Lt's Avatar
Trim Level: Sprot
Rep:20
In that kit that topgunz has that I posted a link to, will the coil spring that they include in the kit raise the rear of the truck? Also that kit I believe said for 09-10 is there any difference in the rear or suspension between the 09,10 and 11. Mines an 11 BTW
Old 05-26-2011, 10:33 AM
Crawler Hauler Crawler Hauler is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Crawler Hauler is on a distinguished road
4 Wheel Parts has a special this month on the PLS600 kit from Performance Accessories. It's $468 for a 5" kit that clears 35s easily.
