Old 05-19-2011, 03:36 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default Cold air intake, program computer
i just ordered a new cold air intake for my 2010 dodge ram 1500 reg. cab, i was wondering if i would have to send my computer in to get reprogrammed.. or where i would send it.
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 05-19-2011, 03:42 PM
You won't need to re-program it. It may throw a code the first time you start it up but that happens sometimes. The PCM's do learn (they have some adaptive properties) so there's no need to send it anywhere. Just put on your CAI and go.
You might consider getting a programmer one day, especially if you also do exhaust. The programmer will help you reap all the benefits of the additional air in and out.
Old 05-19-2011, 04:02 PM
Color: Gloss Black
Rep:141
thank you for the help. my next step is swapping my stock exhaust out.
i was thinking of just making it a straight pipe. what do you suggest?
what are the specs of the muffler?
Old 05-19-2011, 10:04 PM
Kindanocturnal's Avatar
Kindanocturnal Kindanocturnal is offline
Color: Black/sandstone
Rep:38
Kindanocturnal is on a distinguished road
I don't have the answer to your question but my question is along the same lines so I figured I would jump in. I also just picked up a cold air intake for my 2010 Ram. I have the Laramie w/ factory dual exhaust so I only planned on a programmer; Is there a programmer that anyone can recommend?
Old 05-19-2011, 10:10 PM
incubus868's Avatar
incubus868 incubus868 is offline
Vehicle: 2014 Ram
Trim Level: Larimie
Color: True Blue
incubus868 is on a distinguished road
A straight pipe is really loud I had it for a little then put a muffler on and now I just have a turndown after the muffler with no resonator. I just used a cheap thrush and it sounds great. As far as a programmer goes you can't go wrong with the predator.
Old 05-20-2011, 08:52 AM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Here are some good threads on exhaust:
http://www.ramforumz.com/showthread.php?t=71908
http://www.ramforumz.com/showthread.php?t=81832
As for the tuner, no question the DiabloSport Predator seems to be the most popular on this forum. They do not make them for the 2011 models yet but should have them available for earlier versions. Do a Google search and you will find plenty of vendors that sell them. (Disclaimer: I have a 2011 and do not have a tuner (yet) so I can't give any opinion on how effective they are).
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 05-22-2011, 07:55 AM
texaskid's Avatar
texaskid texaskid is offline
Vehicle: 2010 1500 trx4
Trim Level: trx4
Rep:22
texaskid is on a distinguished road
i have the superchips flashpaq and its very noticable on the 4.7s
Old 05-22-2011, 01:06 PM
wolfman10's Avatar
wolfman10 wolfman10 is offline
Trim Level: SLT- Lonestar
Rep:188
wolfman10 has a spectacular aura aboutwolfman10 has a spectacular aura about
You can also disconnect the battery before you install the intake and then connect it back once you are done. It can help the computer adjust quicker to the new intake.
-Cody
My Build: http://www.ramforumz.com/showthread.php?t=86853
Old 05-22-2011, 01:36 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
good info by wolfman....in the install instructions it tells you to disconnect the battery
Old 05-22-2011, 03:49 PM
Most folks just replace their muffler(s) with some freer flowing aftermarket units. I went with a Magnaflow 18" unit because I like the sound of those.
I have two HEMI powered vehicles and both of them have the DiabloSport Predator programmer loaded on them. I like how it works, I like the tuning flexibility, I like the changes you can make. See my "Ram Mods" link below and scroll to page 2 to see real world results of the DS 91 octane program on the truck HEMI.
Cold Air Intake & Ram Air Hood? Stonednloaded Body & Interior 1 05-06-2011 02:12 PM
Closed air box cold air intake? wickedpissahtruck 2010 Dodge Ram Forum 1 05-05-2011 10:26 PM
Cold air intake info please E220 2011 Dodge Ram Forum 13 04-15-2011 01:27 AM
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 10:31 PM
