Place your Ad Here!
Old 05-19-2011, 05:28 PM
wannab's Avatar
wannab wannab is offline
Vehicle: 2011 Hemi sport
Trim Level: Sport QC.
wannab is on a distinguished road
Default Ram air mod
I have not done it, and probably wound, but if you relocate the washer fluid box you can run flex tube or pvc to your intake and get a great ram air system. It was a big thing on the Ttian and I gained 3 tenths 0.60 per my Gtech.
2011 Black Sport Quad cab Ram, Magnaflow midpipe back exhaust, K+N intake.
Old 05-20-2011, 11:31 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I think that would work well so, it's time to .................... this back to the top!
Old 05-24-2011, 02:40 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
No can-do my friend,
The washer fluid container is Way over on the other side of the rad from the air box on the 4G Ram Hemi.
The best place for a Ram Air is the passenger side, if you remove the stock airbox you will see where the opening is just behind the passenger side headlight.
This is the same inlet almost every aftermarket CAI uses... IMHO, WAY too small and the feed from below is not as good as it could be...
My Airaid
View from the engine bay, airbox removed
Here's what the air path looks like from the front with the headlight removed on a friends Ram at the track.
Now get on a creeper and stick your head under the front bumper
look up the passenger side wheel well liner until you see where the air inlet for the stock air box is...
Before pic:
The Key to getting more air up there is here: Phase 1 of the "BRH" ram air I should patten that before someone steals it and markets it for Millions!
Look a little closer...
I Dumped the goofy plastic fake grill, It doesn't even match the Black Honey Comb grill anyway and just blocks air flow.
My Next step is to mold a funnel/tube to scoop up the air that would normally be blocked by the fake grill, and direct it in and up the stock path of travel
If all goes well I'll eventually track down another honey comb grill and graft it onto the outer portion of the stock surround trim after it gets some surgery
the end result would look similar to MGH's twin turbo'd beast
...That's where he put his intercooler
Old 05-24-2011, 05:37 PM
wannab's Avatar
Wow, it is the coolant tank. I was not even paying attention. I just got my K+N today, so after install I am going to try and run a flex hose to the bottom grill. And feed in the the side the the K+N intake box. The Titan had the washer box right in front of the intake. I was messing with it when I first got the truck and was not paying attention.
Old 05-24-2011, 09:42 PM
2BlueCrew's Avatar
2BlueCrew 2BlueCrew is offline
Vehicle: 2011 RAM Crew
Trim Level: Sport 4x4
Color: Deep Water Blue Pearl
Rep:23
2BlueCrew is on a distinguished road
Default Word of caution
With all due respect to BRH and his very creative way of increasing air into his CAI, just a word of caution: The lower you move your air source, the greater your risk of HydroLocking your engine. By the looks of BRH's mod, the air source has been lowered about 18" or so. I once HydroLocked my '86 F-150 driving through a deep puddle in S. Fla after a heavy rain. Come to find out, F0rd put the air intake just above the front bumper and when pushing a slight wall of water, I took in water. Whamm -- HydroLocked. So again, just a word of caution, be careful when you lower your air source and/or keep mindful of where it is should you lower it. Don't do deep puddles and/or do them slowly. Otherwise, great idea...
[COLOR=blue]"Do not answer a fool according to his folly, or you will also be like him" Proverbs 26:4[/COLOR]
Old 05-24-2011, 10:04 PM
wannab's Avatar
Very good point, I removed the intake out of my Acura for that reason. But i think when you are running a tube or pipe to a box that is not directly piped to the throttle body you are not sucking any water right in to it. It is more like spraying on the filter and not going directly into the tb. Japanies car are big on hydro lock.
Old 05-24-2011, 11:03 PM
Rep:561
I'm just redirecting air flow, no actual tube would be running all the way up. Still a very open path,
no different than stock other than feeding air from the front instead of from below (same height)
There are so many 90 bends and twists along the path that it would be nearly impossible to get the filter element even slightly damp, yet alone Hydro-Locking the engine.
I've been into Offroading since the early 80's
and served as a Trail Leader for the Jeep Jamboree program for many years too.
I've pulled more than my share of n00b's out of a River crossing, had them shut their engine off,
get to the other side to pull all their plugs and turn the engine over to pump the water out of the cylinders.
This vid was shot during a Training run teaching river crossing techniques to new trailguides:
(I've done several deeper crossings with water well over my hood)
Enjoy: http://members.shaw.ca/spound/julylo...long02_pt2.wmv
My last Jeep (had 5 of them) an 01' TJ built up 100% by myself with the help of my brother
No worries
Old 05-25-2011, 07:47 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
if i remember right, there was a "claimed" solution to getting hydro'd, and this was a few years ago now
there was some sort of sponge filter or something that was installed in-line about half way up the intake tube....AEM maybe??
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 05-25-2011, 07:49 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
here ya be
http://www.aemintakes.com/air_bypass_valve.htm
Old 05-25-2011, 10:19 PM
wannab's Avatar
Nice Jeep, I had one in 85, never modded it but did a lot of wheeling in the jersery pines.
Kegger MOD DIY wermbang Dodge Ram Knowledge Base 8 09-09-2012 02:05 PM
TB and CAI mod question ddenton Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 3 05-19-2011 07:11 PM
XTRA POWER MOD moved IAC sensor from Manifold to Intake tube RAMING IT Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 6 05-09-2011 09:05 PM
2001 Dodge Ram Air Conditioning westbygodtbone Heating & Cooling 1 05-03-2011 10:18 PM
Keggar Mod wermbang Dodge Ram Knowledge Base 1 04-05-2011 02:16 AM
